Activity Forums Avid Media Composer exporting text subtitle file from avid
  • exporting text subtitle file from avid
    Posted by Lucia6 on June 12, 2006 at 10:42 pm
    I’m trying to export my subtitles from an Avid project as a text file that I can then convert to a stl file that I can import into DVD Studio Pro. The text file needs to include inpoint, outpoint and subtitle line. Anyone know how to do this?
    Lucia
    Filip replied 19 years, 12 months ago 3 Members · 4 Replies
  • John Grote, jr.
    June 13, 2006 at 2:22 pm
    Good day Lucia6,
    I was wondering if you could give us a little more information about what exactly you are trying to do with the subtitles?
    Thanx,
    btveditor
  • Lucia6
    June 13, 2006 at 3:01 pm
    I am trying to bring the subtitles I made in Avid into DVD Studio Pro’s subtitle track. Ideally this would be done in such a way that I could edit the subtitles in DVD Studio Pro if needed. So, initially I need to figure out how to export a text file for the subtitles in my Avid project.
    Lucia
  • John Grote, jr.
    June 13, 2006 at 3:41 pm
    Good day Lucia6,
    The one way that I know how to export title out of AVID is from inside Title Tool itself. You would have to open each title and then right click the mouse and select export title, but it only exports the title as a pict file. Also, once you have done that, it will not allow you to edit the text, you’d have to go back into Title Tool to do that.
    btveditor
  • Filip
    September 27, 2006 at 3:51 pm
    lucia,
    did you find anyone who helped you in this question? i have the same problem now as you.
    do you know proper wokflow or maybe someone who can help?
    thank you
    filip
    p.s. if you want – you can contact me via my private mail:
    tri_color(at)poczta.onet.pl
    (instead (at) use @ of course.)
