Activity › Forums › Apple Final Cut Pro Legacy › Exporting text from FCP to After Effects ¿How export with alpha?
  • Exporting text from FCP to After Effects ¿How export with alpha?
    Posted by Carlos Ruiz on August 31, 2009 at 6:27 pm
    Hi, first again sorry for my english
    Im trying to do something looks easy but i dont know how can i do it.
    A have a sequence with animated text in final cut and i want to import in after effects. The FCP Seq, only have the text layer, but when import in after effects have a black background.
    I try exporting as a tga sequence, in animation color +…. but the problem its the same.
    Someone could help me?
    Thanks a lot.
    Carlos.
    Carlos Ruiz replied 17 years ago 6 Members · 7 Replies
  • 7 Replies
  • Aaron Neitz
    August 31, 2009 at 7:10 pm
    Just plain white text on black?
    in after effects use the layer as it’s own luma matte.
  • Carlos Ruiz
    August 31, 2009 at 7:27 pm
    Thanks for ur answer.
    Its an animated text white and red.
    Regards.
  • John Pale
    August 31, 2009 at 7:46 pm
    Make sure it is NOT RENDERED before you export. If you render it makes a composite with the empty background.
  • Lance Moody
    August 31, 2009 at 8:27 pm
    Hmm…check to be sure that you have nothing (like a black layer, for instance) filling the background (use View>Background>Checkerboard to check this).
    I would suggest exporting the sequence as an Animation codec Quicktime and be sure to include an Alpha (millions of colors +). Should work fine.
    Lance
  • Andreas Kiel
    August 31, 2009 at 9:02 pm
    One way is to add an empty text generator which covers the complete timeline, then export.
    Andreas
    Spherico
    https://www.spherico.com/filmtools
  • Brendon Killen
    September 1, 2009 at 1:21 am
    what lance said
  • Carlos Ruiz
    September 1, 2009 at 7:01 am
    Hi again,
    Thanks for ur interest, the text layer its created with the effect: CGM DVE TEXT “Karaoke”, its works like a normal layer, and when change the background in checkboard its transparent. I tried Animation Codec with “millions colors+” too, and the problem against…
    Thanks anyway.
