Activity Forums Adobe After Effects Exporting Targa with Alpha
  • Exporting Targa with Alpha
    Posted by Sean Tyler on February 7, 2012 at 3:10 pm
    I’m trying to deliver a clip to my 3d guy, and he is using CS4, I have CS5.5… He wants me to render a “Targa Sequence with Alpha”.
    The clip was edited in PP, then Warp Stabilized and Reversed Time, and has a tight garbage matte applied, using the Autotrace method.
    I’ve tried several times using the render queue, though it was first time using it at all. He says he’s not getting the alpha channel, that he needs to see the checkered background, but it’s not there.
    Any thoughts on what I’m missing here, besides a proper background in AE?
    Niels Bosch replied 11 years, 7 months ago 6 Members · 8 Replies
  • 8 Replies
  • Michael Szalapski
    February 7, 2012 at 4:19 pm
    In AE, do you have a checkered background to your comp? You can toggle the comp view from the background color (default black) to the checkerboard.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Sean Tyler
    February 7, 2012 at 4:25 pm
    Yes, I believe so, I see the checkerboard background and there are no layers beneath the keyed layer…
    s
  • John Cuevas
    February 7, 2012 at 4:41 pm
    In the Output Modulue lossless settings have you changed your Video Output pulldown Channels to “RGB + Alpha”?
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Sean Tyler
    February 7, 2012 at 4:44 pm
    Yes, I’ve selected Targa Sequence and RGB + Alpha
    S
  • Sean Tyler
    February 8, 2012 at 7:40 am
    Thanks for the help everyone, ending up using a “tiff with alpha”, that one seemed to work just fine…
    s
  • Angie Taylor
    February 8, 2012 at 10:06 am
    When you render, go to the Output module settings and make sure that the Channels menu is set to RGB+Alpha and Millions of Colors +;
    Here’s some info to help you;
    https://www.video2brain.com/en/videos-1450.htm#/?video_id=1542
    cheers,
    Angie
    Angie Taylor animation & illustration for television, film, web and devices
    https://www.angietaylor.co.uk
    Twitter: theangietaylor
    Linkedin: theangietaylor
    https://www.facebook.com/pages/Angie-Taylor/118378194869002
  • Renaud Hericord
    February 18, 2014 at 11:04 am
    Targa options have to be in 32 bits/pixels otherwise it doesnt get the alpha
  • Niels Bosch
    February 12, 2015 at 10:04 pm
    Dave youre my hero, turning it to 32 bit did the trick, bless!
