Activity Forums Adobe After Effects exporting swf file
  • exporting swf file
    Posted by Esteban Duperly on July 18, 2007 at 11:25 pm
    Hi there!! I’m animating two objects in AF. Although its final output will be a flash multimedia, I’m doing the animation work in AF just because the movements are quite complex. I’m exporting my movie as a swf file and setting the image quality to best. The outcome is that the swf movie
    Esteban Duperly replied 19 years, 1 month ago 2 Members · 4 Replies
  • Mike Wheeler
    July 19, 2007 at 12:53 pm
    Try exporting as an “FLV” .. then you can bring that into Flash.
  • Esteban Duperly
    July 19, 2007 at 2:18 pm
    Thanks Macohead! It worked fine. Just one more thing, the file I imported into AF is a vectorial file (Illustrator). When exporting it as flv and bringing it into Flash vectors turn into pixel images. Is there a way I could keep the clip as vecotrs in order to avoid pixelation.
    Thanks again!
  • Mike Wheeler
    July 23, 2007 at 2:26 pm
    Hey..
    Sorry, Don’t know the answer to that one!!
    …I always select custom compression and crank up the “Max data rate” to improve the quality of the video… although this won’t always be the solution if you are worried about file size…
  • Esteban Duperly
    July 24, 2007 at 8:44 pm
    no prob mate!! thanks for the help!
