Activity › Forums › Apple Final Cut Pro Legacy › Exporting Subtitles with Transparent BG from FCP into PSD Sequence
  • Exporting Subtitles with Transparent BG from FCP into PSD Sequence
    Posted by Rajnesh Domalpalli on December 5, 2007 at 8:48 am
    Hi All,
    I’m trying to export Subtitles from FCP to a Photoshop Image Sequence.
    I need the output to have transparent Background, but it keeps coming up as Black.
    In the Canvas, I have tried the following combinations:
    1. RGB + Checkerboard 1
    2. Alpha + RGB + Checkerboard 1
    3. Alpha + Checkerboard 1
    But in all the cases, the background keeps coming up in photoshop as Black.
    How should this be done?
    Thanks in advance.
    Regards,
    rajnesh
    Rajnesh Domalpalli replied 18 years, 10 months ago 3 Members · 3 Replies
  • Bouncing Account needs new email address
    December 5, 2007 at 3:18 pm
    Here is a post I saved about exporting with an Alpha Channel (transparent BG) from FCP.
    Date: Nov 16, 2007 at 9:19:06 pm
    Subject: Re: Chroma Key without replacing background
    After you pull the key, leave the sequence UNRENDERED on track 2 with nothing on track 1 (empty) and then Export > Quicktime Conversion. Change the format to ‘Quicktime Movie’ then hit the options button.
    CLick the ‘Settings’ button in the video portion and keep the frame rate @ current change the compression type to Animation and be sure the depth says ‘MIllions of Colors+”. The plus (+) is an alpha channel. Click OK.
    Change the audio settings to whatever is best for you (linear PCM, 48k, 24 bit). Click OK.
    name the file, set a destination, then click save.
  • David Bogie
    December 5, 2007 at 4:31 pm
    Matte’s quote from JG will get you quite far but I’ve got to ask the question, “Why are doing this?” We’ve probably got a better workflow suggestion for you if you’ll explain your purpose in sending video stills of text from FCP to Photoshop.
    bogiesan
  • Rajnesh Domalpalli
    December 5, 2007 at 7:30 pm
    Thanks for replying.
    We’ve got a subtitled project in FCP. The Lab has a D5 Tape of the Film without Subtitles. They need to write a D5 with the Subtitles that we have in FCP. They told us that if we gave them a Photoshop Image Sequence of the Subtitles with a Transparent BackGround, they would import and overlay them directly saving us cost.
    In Matt’s post, he talks of Pulling the Key… Could you also explain how to do this/ where to look it up in the Manual. Also, I get the impression that he is referring to a Single Frame being Exported. I need to export a Photoshop Image Sequence.
    Regards,
    Rajnesh
