Activity Forums Apple Final Cut Pro Legacy exporting stills… is there a quicker way
  • exporting stills… is there a quicker way
    Posted by Chris Miller on February 24, 2006 at 11:46 pm
    Hi
    I need to select 100’s if not 1000’s of stills from some dv footage. Is the only way to export using quicktime conversion? It take too long.Even if I could keep the format to still image instead of having to change the format every time it would take one stage out of the process. Is there a script I could use, or a plug in?? Thanks!!
    Bryce Whiteside replied 20 years, 6 months ago 4 Members · 4 Replies
  • Shane Ross
    February 24, 2006 at 11:55 pm
    Nope…sorry. There are no scripts…automator does not work with FCP, and no plugins exist for this. This is a manual thing, and I agree, it is a pain. It would REALLY help if when choosing export, it defaulted to the last export type you just did.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Chris Miller
    February 25, 2006 at 12:01 am
    bummer thanks for quick response………best
  • Nick Toth
    February 25, 2006 at 12:15 am
    Use Quicktime Pro to export an image sequence and then choose the files you want. You can set up actions in Photoshop to batch process the files you choose.
  • Bryce Whiteside
    February 25, 2006 at 2:35 am
    Wilko needs to read this post Re: automating stills exports by NIckM on 2006-01-01 22:43:31
    Inquiring minds,
    Bryce Whiteside
    Don’t worry Mr. B. I have a cunning plan…
    PowerBook 1.67 Ghz ATI 9700 128 MB 2 GB
    Mac OS X 10.4.5 QuickTime Pro 7.0.4
    Final Cut Pro HD
    DVD Studio Pro 3
    Motion
    After Effects 6.5
