Activity › Forums › Apple Final Cut Pro Legacy › exporting still images
  • exporting still images
    Posted by Whatthejones on May 30, 2007 at 3:13 pm
    I’m working on a video right now that requires a few title screens within the video. They look fine when I import them and put them on the timeline on my screen and my tv monitor, but when I export the quicktime they get pretty blurry.
    I don’t know if it’s the picture format I imported (I’ve tried a few) or if there’s something I could do to my export settings.
    any suggestions?
    Russell Lasson replied 19 years, 4 months ago 4 Members · 4 Replies
  • Richard Martz
    May 30, 2007 at 4:09 pm
    Do you mean that you are exporting stills using quicktime conversion? Or that your stills are gettting blurry after you import them into your timeline for editing?
    Richard Martz
    MagicMartz Media
    Final Cut Pro HD
    Kona LH
    After Effects
    PhotoShop
    Illustrator
    Lots of other Fun Stuff!
  • Whatthejones
    May 30, 2007 at 4:26 pm
    it’s when I export the timeline as a quicktime, it’s mostly video elements, which all look fine, it’s just the logos and titles that look bad. It looks fine on my monitor when it’s in the timeline for editing, it only looks bad in the quicktime I export using current settings
    I should clarify, I’m not exporting still images, I’m exporting a video timeline with picture files on it.
  • David Roth weiss
    May 30, 2007 at 5:53 pm
    From your decription its clear that your working on a DV timeline. What you’re experiencing is the DV compression hit on your graphics.
    To avoid this you can either 1) cut and paste everything into a 8-bit uncompressed timeline and render, or 2) change your compressor setting on your current timeline in Sequence Settings to 8-bit uncompressed and re-render.
    David
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Russell Lasson
    May 30, 2007 at 8:58 pm
    If you are exporting a QuickTime DV file and viewing it in QuickTime Player, chances are it doesn’t look as bad as you think.
    Check to see if High Quality video was selected in QT – Movie Properties – Video Track – Visual Settings window.
    DV files normally look like crap in QT unless this is selected.
    -Russ
