Activity Forums Apple Final Cut Pro Legacy Exporting still image field/interlace problem
  • Exporting still image field/interlace problem
    Posted by Ben Trahair on April 15, 2006 at 12:28 am
    Hi guys and gals.
    Just a question regarding field/interlace issues in FCP.
    I am trying to export stills from footage shot on DV (both mini and DVCpro) and with all manner of options experimented with I keep getting a really horrible comb type interlaced image. I have tried turning fields on and off in the sequence settings, exporting with and without interlace and tried changing the default dv rendering with FCP to progressive from interlaced but still get the exact same result every time.
    The reason I’m exporting is to animate the stills for a client in after effects. They normally have supplied me with the images already but I don’t seem to be able to get things to work myself. Suggestions?
    Ben Trahair replied 20 years, 5 months ago 2 Members · 2 Replies
  • Bill Kelly
    April 15, 2006 at 12:31 am
    I generally just export the still image as-is from the timeline, then deinterlace in photoshop (filters>>video>>deinterlace). Usually works okay.
  • Ben Trahair
    April 15, 2006 at 12:38 am
    ahhh. Magic.
    Thankyou so much Kel. You have saved me a headache!
    Cheers
    Ben
