Activity › Forums › Apple Final Cut Pro Legacy › Exporting speed
  • Exporting speed
    Posted by Dan Archer on October 11, 2007 at 2:14 pm
    I am running a 2×2.66 ghz intel with 5 gig of ram and FCP 5.1.4. As i am exporting i open the old Activity monitor and noticed that the chips are running at only about 1/3 to half of capacity. Is this Normal? should i ignore the Activity mon, is it lying??? for some reason the machine(s) seem to be exporting slower than they did say last week. i am exporting from 3 machines to the same network but they still seem slower. Any advice would be helpful. Thanks in advance.
    Dan Archer replied 18 years, 11 months ago 2 Members · 3 Replies
  • Russell Lasson
    October 11, 2007 at 3:19 pm
    [lecherro] “should i ignore the Activity mon, is it lying???”
    No, the activity monitor isn’t lying. Often times FCP doesn’t use full processing power to export.
    [lecherro] “i am exporting from 3 machines to the same network but they still seem slower.”
    Exporting speed can depend on a whole bunch of factors. If you have three different machines connected to a network drive on a gigabit ethernet network then chances are, your network or hard drives are more of a factor of speed than your computers’ cpus.
    If you want to tell some more specifics about you’re set up, maybe there will be something that we could help you with.
    -Russ
  • Russell Lasson
    -Russ
  • Dan Archer
    October 11, 2007 at 3:51 pm
    Thanks Russ, thats pretty much what i thought. I dont know a lot about the net, but i do know it has 25 tb of isilon servers, and has pretty big bandwidth. I share it with a couple of different people. who are also doing pretty intensive things such as managing al the flip factory stuff thats constantly going on. thanks for your help.
