Activity › Forums › Apple Final Cut Pro Legacy › Exporting Sound Channels to Different AIFF Files
  • Exporting Sound Channels to Different AIFF Files
    Posted by Tabanli2-gmail on October 16, 2006 at 3:12 am
    How can I export different audio tracks to different AIFF files all at once. Is there an option that sets up the timeline so that tracks a1-a2-a3 goes to one AIFF A4-A5-A6 goes to the second etc.
    How can you produce a surround sound with FCP. Is there an easy way. I know I can do this the hard way by exporting the same timeline and checking unchecking some audio tracks. But I don’t want to export the timeline 5 times with different tracks checked.
    Tom Wolsky replied 19 years, 11 months ago 3 Members · 4 Replies
  • Jase
    October 16, 2006 at 11:05 am
    [tabanli2-gmail] ”
    How can I export different audio tracks to different AIFF files all at once.”
    only via OMF what audio prog are you using?
    [tabanli2-gmail] “Is there an option that sets up the timeline so that tracks a1-a2-a3 goes to one AIFF A4-A5-A6 goes to the second etc.”
    only via muting on the tracks. Just turn off the green audio icon. (and assume pan these)
    [tabanli2-gmail] “How can you produce a surround sound with FCP”
    rumoured to be in final cut 6.
    [tabanli2-gmail] “But I don’t want to export the timeline 5 times with different tracks checked.”
    OMF is the only way…..
    J
  • Tom Wolsky
    October 16, 2006 at 11:17 am
    This is quite wrong. You can export Audio to AIFFs and export each track as a separate file or pairs of tracks grouped as stereo pairs. You do this in the Audio Output panel of Sequence Settings. You then assign each track to a separate output channel. You can output up to 24 tracks like this.
    You can specify which track goes to which output channel by right-clicking in the track header and choosing it from the shortcut menu.
    Surround sound can’t be monitored in FCP, but you can export tracks and assign them to specific surround sound channels in Compressor.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Jase
    October 16, 2006 at 11:32 am
    Sorry stand corrected. Thought the output was constrained to the physical audio output of the card.
    Though why not use OMF like everyone else? Pro Tools, Nuendo, Cubase, Logic, Digital Performer all accept OMF.
    Can see it being real handy for programs don’t use OMF though, but they wouldn’t have 5.1 capability.
    J
  • Tom Wolsky
    October 16, 2006 at 3:11 pm
    The most likely reason is that OMF has export limitations. It’s assumed the audio editing, effects and levels control, will take place in the audio software.
    All the best,
    Tom
