Activity Forums Apple Final Cut Pro Exporting small sequences from a large sequence.
  • Exporting small sequences from a large sequence.
    Posted by Dan Crouch on June 25, 2013 at 8:13 pm
    Hi Guys,
    I am trying to export several 2 minute selected scenes from a long documentary.
    I have tried copying the clip, cmd a, then opening up a new project and pasting, but the aspect ratio hasn’t transferred.
    The image is small and when I transform to full screen, it looks like it’s blown up.
    I have also tried to copy whole project then delete the stuff I don’t want, leaving the clip I want to export but this takes ages to copy.
    Is there a quicker way?
    Any help would be fantastic,
    Thank you.
    Dan.
    Bret Williams replied 13 years, 2 months ago 3 Members · 6 Replies
  • Jeff Kirkland
    June 25, 2013 at 8:30 pm
    Just exporting a selected range isn’t working fro you?
    Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
    http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland
  • Dan Crouch
    June 25, 2013 at 9:15 pm
    Thanks for the post Jeff,
    I was under the impression the only way to export was to do it from the project window. Is there a way to do from the timeline?
    Cheers,
    Dan.
  • Jeff Kirkland
    June 25, 2013 at 9:45 pm
    Unless we’re talking at cross purposes, you just open the timeline, select a range and choose your appropriate share option – Final Cut will export just the selected range.
  • Dan Crouch
    June 25, 2013 at 10:57 pm
    Thanks for that Jeff,
    I can see now that it can be done!
    Thanks very much for that. Is it a recent update? I couldn’t find anything online that shows you how to do that, just lots of annoyed editors saying you can’t.
    Thanks again,
    Dan.
  • Jeff Kirkland
    June 25, 2013 at 11:05 pm
    Added in 10.0.6 I think… glad it’s working for you.
    cheers
    Jeff K
  • Bret Williams
    June 26, 2013 at 12:49 am
    And before that you didn’t have to export from the project library. But you couldnt’ do a range select.
