Activity Forums Apple Final Cut Pro Legacy exporting small 30 min clip for post scoring
  • exporting small 30 min clip for post scoring
    Posted by Elliot Pollaro on April 3, 2007 at 9:28 pm
    Im trying to export a 30 minute video to a small format so my pro tools guy can load it on his computer and edit to it no problem for post scoring. The file sizes i have gave him keep freezing up his computer… what should my settings be?
    Russell Lasson replied 19 years, 5 months ago 2 Members · 1 Reply
  • Russell Lasson
    April 3, 2007 at 10:02 pm
    First of all, your post audio guy should have already figured out setting that work for him. It drives me crazy when they don’t have a clue.
    Most post audio guys I work with now just use DV files. But I would suggest using Sorenson 3.
    So copy the text below and paste it into a new text document. Save it and then change the extention from .txt to .setting.
    Then move the setting into the home/library/application support/compressor folder. Open up compressor and the setting should be there.
    There are two setting you can try. Once you’re in compressor you might have to modify the setting for your picture aspect ratio.
    Sorenson 3 640×360
    No%2520descriptionmovyes-1001 1 1 0 Y 0 100 0 0SVQ3SMI 0000no
    Sorenson 3 320×180
    No%2520descriptionmovyes-1001 1 1 0 Y 0 100 0 0SVQ3SMI 819200000no
    -Good Luck
