Activity Forums Adobe Premiere Pro Exporting size is high…….
  • Exporting size is high…….
    Posted by Balu Gabbu on September 26, 2013 at 12:19 pm
    when i export my sequence in pre’pro
    i get huge data video as output…
    for ex:3min of video took 1.36gb of data size
    is there any way for reducing that size?
    what are the processes for that?
    Balu Gabbu replied 12 years, 12 months ago 3 Members · 7 Replies
  • 7 Replies
  • Ivan Myles
    September 26, 2013 at 2:59 pm
    In general, reduce the target bitrate, increase key frame distance to 1-2 times the frame rate (or set it to auto), and use a higher profile to improve quality:bitrate. What codec and export settings did you use?
  • Chris Tompkins
    September 26, 2013 at 6:07 pm
    You did not mention what you are exporting to?
    What file type?
    A 10bit uncompressed file will be much larger then a .mp4 clip for example.
    A mpeg2 is heavily compressed and will be smaller then the original file size by a lot, depending on the data rate.
    What is your delivery?
    Have you looked at all the presets in AME when you export?
    Chris
  • Balu Gabbu
    September 28, 2013 at 2:19 pm
    thanks for your reply…..
    my files properties are here
  • Chris Tompkins
    September 28, 2013 at 2:26 pm
    that is the property of your clips in the sequence; 720p/24p
    But what are you trying to export to? What is your deliverable?
    Chris
  • Balu Gabbu
    September 28, 2013 at 2:33 pm
    sorry to disappoint you ………
    i am a begeinner for professional video editing…
    so where can i find so called bitrate and other props..
  • Ivan Myles
    September 28, 2013 at 7:07 pm
    When you exported the file, what Format did you use and what were the settings under the video tab and multiplexer tab (if applicable)?
  • Balu Gabbu
    September 29, 2013 at 5:07 am
    i will try once…
