Activity Forums Maxon Cinema 4D Exporting shadows for compositing in After Effects
  • Exporting shadows for compositing in After Effects
    Posted by Chris Lenhart on March 10, 2013 at 6:03 pm
    I am struggling a bit with this. I have come over from 3DS Max and am finding there are some big differences. No big deal, I expected that. But now I need to export an animation to After Effects. In 3DS I would just drop the shadow matte material on the objects and export. Not in Cinema it seems. Is there any way to do this without rendering out all the different passes? If I were rendering in Cinema I’d have no issues. But this needs to be done in AE.
    Craig Whitaker replied 13 years, 6 months ago 2 Members · 1 Reply
  • Craig Whitaker
    March 11, 2013 at 4:10 pm
    Chris,
    This is an ongoing discussion in C4D world and there are many workarounds. The one I’ve been using most often is to use compositing tags with “Seen by Camera” unchecked. You can also apply different shaders to speed things up (no reflection, etc). There is a plugin called Render Elements which really helps out with manual render layers, check it out.
    Best,
    Craig
    Craig Whitaker
    Digital Design Director
    Assembly
    161 Leverington Avenue Suite 1002
    Philadelphia, PA 19127
    O: 215-487-2060
    craig@assemblypix.com
