Activity › Forums › Adobe Premiere Pro › Exporting Settings & Quality Problems
Posted by Steven Sall on October 9, 2013 at 10:20 pmHello – I am having a problem with exporting. I will try to post my sequence settings and the default export settings that I did do for an export and the image quality came out very poor and I had horizontal lines over a lot of the footage.
The footage is shot with a GoPro Hero 3 Black wity 720 @ 120fps.
I would like to export to be viewable on a TV via USB so .mov would be preferable? Either way I am looking for the best quality possible.
Again, any help will be very much appreciated!!
and
Steven Sall replied 12 years, 11 months ago 2 Members · 6 Replies -
Ivan Myles
October 10, 2013 at 3:59 amThank you for posting your settings. It is very helpful when troubleshooting. The lines you saw were probably because the file was exported as interlaced but the source footage is progressive. For clarification, why is the sequence 119fps if the source material is 120fps?
What are the TV’s requirements for video files? Things to look for include supported codecs (H.264/MP4 vs H.264/MOV vs other), maximum Profile and Level, maximum bitrate, and maximum frame rate at 720p and 1080p.
Pending further info regarding the TV specs, I would recommend using 1280×720-60p and letting the TV up-convert on the fly rather than exporting at 1080p. Also, a higher bitrate will yield better quality. Try making a short test file at different rates from 10-20 Mbps to see what the TV/USB can play.
Steven Sall
October 10, 2013 at 5:53 pmHi Ivan:
Thank you for your advice. I tried it, below are my export settings. The video plays well however the edges are really pixelated and the colors seem to be a bit out of wack when i play it on my computer and tv(via usb). Should I try a different mbps? lower or higher?
The profile is set at high and level at 5.1.
Thanks again!
Ivan Myles
October 10, 2013 at 9:09 pmGlad to hear you are making progress. Try 20 Mbps Target bitrate with 30 Mbps Maximum using High Profile at Level 4.1. There is no advantage to using a higher level in this case (but not much penalty if the TV supports L5.1). Also, set the Level first and then check the other settings; Premiere Pro resets some of the parameters whenever the Level is changed.
Scroll down to the Advanced section in the Video tab and set Key Frame Distance to 20 frames. Click on the Multiplexer tab and check that Multiplexer is set to MP4 and Stream Compatibility is set to Standard.
You could potentially go up to 25 Mbps target bitrate with 40 Mbps maximum. Beyond that should not make much difference with 2-Pass VBR unless there is a lot of motion throughout the video. The video might start stuttering if the bitrate is too high for the TV.
To check the colors, import the encoded file back into Premiere Pro and insert it in a sequence with the edited footage. Set either the Reference Monitor or Program Monitor to All Scopes or RGB Parade. In the timeline panel, toggle the track with the encoded footage on and off. Watch the scopes to see if there is a significant difference in the waveforms between the edited footage and the encoded file. It is normal to see a slight shift, but it should not be more than a few IRE difference on the scale. If you see a major difference please post screen captures of the scopes for a frame of the edited sequence and the same frame of the encoded H.264 file.
Steven Sall
October 11, 2013 at 7:26 amThanks Ivan.
I tried those settings – I believe it turned out to be the same quality which is ok. Just not great.
Is it normal to fully render the sequence first before exporting? Does that yield a better quality end result?
Ivan Myles
October 11, 2013 at 10:36 am[Steven Sall] “I tried those settings – I believe it turned out to be the same quality which is ok. Just not great.”
Were you able to import the encoded file back into Premiere Pro and compare it to the source clips in the edited sequence? The degradation in quality when playing on the TV might be caused by the hardware, not the file. (For example, one of my displays is prone to banding and blocking even though the same videos look fine on other monitors.)
[Steven Sall] “Is it normal to fully render the sequence first before exporting? Does that yield a better quality end result?”
The question could be interpreted a few ways:
– If you are referring to the encoding process, the only times a sequence is fully rendered prior to encoding is when preview files are used (i.e. smart rendering), or an intermediate file is created. Otherwise, frames are rendered and encoded one after another as part of a single process.
– If you are referring to two-pass VBR encoding, then, yes, two-pass typically generates better quality than single pass encoding at a given bitrate. (Alternatively, two-pass generates the same quality as single pass but at a lower bitrate.)
– If you are referring to running test files, then no, it is not always necessary. That said, it probably should be done more often, especially when one is learning about the different encoding parameters.
Steven Sall
October 11, 2013 at 7:49 pmThanks Again!
I believe my rendering question was referring to.
“- If you are referring to the encoding process, the only times a sequence is fully rendered prior to encoding is when preview files are used (i.e. smart rendering), or an intermediate file is created. Otherwise, frames are rendered and encoded one after another as part of a single process.”
