Activity › Forums › Apple Final Cut Pro Legacy › Exporting settings from a P2 HDV 720P (24fps) to Standard SD (DV)
Posted by Luiggi Berrios on March 3, 2008 at 2:51 amI did my first HDV proyect from a P2 camera shot at 24fps, I did all mt editing on FCP 6.02 and now I’m ready to go to make some Beta SP copies and some DVD’s but I need to downconvert since my converter just did DV through Firewire. Please let me know whats the turnaround to follow.
Ross Byron boughton replied 17 years, 6 months ago 3 Members · 4 Replies -
David Roth weiss
March 3, 2008 at 6:04 am[Luiggi Berrios] “now I’m ready to go to make some Beta SP copies and some DVD’s”
For DVDs you don’t downconvert before encoding to MPEG2, the downconverting happens during the encoding process. If you’ve made DVDs before from SD video in FCP, just do it the same way, just make sure to choose the 16×9/letterbox in Compressor, which will create a DVD that displays 16×9 on a widescreen TV and letterboxed on a 4×3 TV.
As far as outputting to Betacam, you first need to tell us what card you using for that, Then, what type of beta tape are you making, 16×9 anamorphic, letterboxed, or centercut fullscreen?
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
Luiggi Berrios
March 3, 2008 at 4:02 pmThanks david, I have a DA-MAX old converter from Promax and I want to output through it to a Betacam SP analog recorder. Since I have to export the HD 720P (24FPS) proyect from FCP to a normaol NTSC DV 720X480 proyect what is the turnaround to follow.
David Roth weiss
March 3, 2008 at 8:15 pmFor exporting to betacam, open a new timeline and change the settings to SD 8-bit uncompressed. Now, copy everything on your HD timeline and paste that into the new timeline, making certian that you do not allow FCP to change the settings to match the footage. Now, you’ll need to resize every shot depending on if want to go letterboxed, anamorphic or centercut.
When your done with that you can export a DV copy from that timeline.
David Roth Weiss
Director/Editor
