Activity Forums Apple Final Cut Pro Legacy Exporting Sequence with transparent background
  • Exporting Sequence with transparent background
    Posted by Jonathan Lester on January 7, 2010 at 4:08 am
    HI guys.
    I have a 5 second sequence of cropped PNG frames that have a character with a transparent background. I need to do 2 things:
    1) Make the series of 30+ individual PNG frames a single clip (via exporting or whatever) so I can add effects such as fades and dissolves
    2) Export the finished product into After Effects while mainting the transparent background. Once a desired effect is applied, send that file BACK to FCP to be placed in the final product for futher editing.
    I’ve been reading it has something to do with an alpha channel and the animation codec. I’ve tried everything I know of (and could figure out on my own) and still could not get the desired transparency.
    Please help. 🙁
    Jonathan Lester replied 16 years, 8 months ago 4 Members · 6 Replies
  • Rafael Amador
    January 7, 2010 at 4:35 am
    Hi Johnathan,
    You could import directly your stills to AE and work with them as with a movie.
    If you want to make a movie with them in FC, you have to lie them in a sequence with a codec supporting Alpha channel (Animation, Prores 444, Sheer,..). To activate the Alpha Channel, so your clip retain the transparency, you must check “Millions of Colors” in the compressor (codec).
    Rafael
    http://www.nagavideo.com
  • Adam Taylor
    January 7, 2010 at 12:38 pm
    Rafael – i may be wrong but i thought the alpha channel is the option “millions of colors+” – where the + denotes the alpha channel
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
  • Rafael Amador
    January 7, 2010 at 1:15 pm
    You are absolutely right Adam.
    I didn’t type the “+”.
    Cheers,
    rafael
  • Jonathan Lester
    January 7, 2010 at 2:38 pm
    I’ve tried exporting all the individual frames with the animation codec, using millions of colors+, into a single quicktime file, but then when I put it back into FCP, the background is solid black, even when placed on top of a second clip. (?)
  • David Bogie
    January 7, 2010 at 3:57 pm
    [Jonathan Lester] “I’ve tried exporting all the individual frames with the animation codec, using millions of colors+, into a single quicktime file, but then when I put it back into FCP, the background is solid black, even when placed on top of a second clip. (?)
    the interpolation of the alpha is set incorrectly.
    There’s not need to be doing this in FCP, you’re just adding several apparently difficult steps and, for you, complicated functions. Do it in AE.
    bogiesan
  • Jonathan Lester
    January 7, 2010 at 4:44 pm
    Thanks guys. I wound up just importing the still images into AE, running them together (tediously, since I’ve only used the program twice) then exporting it back to FCP. Worked great!
    Now, I’m just trying to find a tutorial for my effect. Thanks for the help!
