Activity Forums Apple Final Cut Pro exporting sequence with different aspect ratios.
  • exporting sequence with different aspect ratios.
    Posted by Dan Crouch on April 12, 2013 at 11:12 pm
    I have just cut a showreel for a friend. Some stuff HD, some SD.
    In FCP X it all seems fine, but when I export it to Vimeo, some of the clips are full height anamorphic, some are in a box in the middle of the screen.
    Can anyone please help with this?
    In FCP 7 you could see the aspect ratio in the timeline and adjust, but on FCP X it alooks great, until you export. I also can’t see where you adjust.
    Any help would be very much appreciated.
    Cheers,
    Dan.
    Claude Lyneis replied 13 years, 4 months ago 4 Members · 9 Replies
  • 9 Replies
  • Charlie Austin
    April 13, 2013 at 1:29 am
    What are the FCPX sequence settings? I don’t use Vimeo, but I just looked the resolution choices in the destination settings, and it’s fairly limited. I’d export a master file from FCPX and upload it to Vimeo through a browser. Again, not a Vimeo user so I’m not sure….
    ~”It is a poor craftsman who blames his tools.”~
    ~”The function you just attempted is not yet implemented”~
  • Bill Davis
    April 13, 2013 at 6:54 am
    [Charlie Austin] “I don’t use Vimeo, but I just looked the resolution choices in the destination settings, and it’s fairly limited.”
    That’s because the Vimeo model is that the service does any required transcoding to do download downrez versions for you. You post a single high-rez master to them, and they use the big iron to version and serve optimized lower rez files to those connecting with pads and mobile devices.
    So the only real user choice that matters, is the resolution you select for your original FCP-X timeline. After that choice, the share menu choice to target Vimeo automates the rest of the process.
    It’s one of my favorite aspects of the X-to-Vimeo-to-the-world workflow. One click and you’re done.
    FWIW.
    Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com – video editing curriculum complete with licensed practice content.
  • Dan Crouch
    April 13, 2013 at 7:15 am
    I have just tried it aka a master file, and then upload but it’s the same problem.
    Can you please tell me how to adjust sequence settings? I think that is the problem.
    V new to Fcp x.
    Thanks in advance,
    Dan.
  • Charlie Austin
    April 13, 2013 at 7:24 am
    [dan crouch] “I have just tried it aka a master file, and then upload but it’s the same problem.
    V new to Fcp x.”
    The sequence (fcpx project) settings can be found by selecting the sequence in the project library, and opening the inspector. At the lower left corner of the inspector window you’ll see a little wrench button. clicking that opens the timeline/project settings pane. As with everything, I’d duplicate the sequence and make changes to the duplicate just in case. Hope this helps…
    Also… does the Master File you exported look OK?
  • Dan Crouch
    April 13, 2013 at 7:37 am
    Thanks for the post,
    I still can’t seem to find the sequence settings. I can see the ratio’s in the inspector of the
    clips but not the sequence settings.
    There is a jpeg, 3600 x 2400, some TV stuff at 768 x 576 and film stuff at 1024 x 576.
    Here is a linl to the problem.
    https://vimeo.com/63938222
    I think the jpeg photo at the top is too big, but it all looks fine on the timeline.
    Thanks again in advance for any help.
    Cheers,
    Dan.
  • Charlie Austin
    April 13, 2013 at 7:58 am
    [dan crouch] “Thanks for the post,
    Thanks again in advance for any help.”
    If you have the project (sequence) open in the timeline and select “Project Properties” from the “File” menu. it will switch to library view, open the inspector and you should see the wrench icon in the lower right of the inspector window.
    it does seem like the project size is too big. Another thing to maybe try, is to click on each clip in the timeline, open the inspector “video” tab, scroll down to “Spatial Conform”, and see what that is set on for each clip. Try changing that setting and see what happens. I wish I could say “do this..” but I can’t. Just some suggestions…
  • Dan Crouch
    April 13, 2013 at 8:06 am
    Thanks for the post Charlie,
    I have now found the settings and will try a few things.
    I’ve just set the timeline to most common aspect ratio and I’ve resized jpeg in photoshop.
    I have to export it it Vimeo each time to see if it works!
    Thanks or your help.
    Dan.
  • Charlie Austin
    April 13, 2013 at 8:11 am
    [dan crouch] “Thanks for the post Charlie,
    I have to export it it Vimeo each time to see if it works!”
    cool… As I said, in addition to the Project (sequence) settings, you can also change each clips’ Spatial conform setting in the inspector. It could be a combination of project aspect ratio, and each clips setting. Just fiddle around, that’s how I figure this sort of thing out.. lol I hope you’re messing with a copy of your original. 😉 Hope it works!.
  • Claude Lyneis
    April 13, 2013 at 5:47 pm
    If you use the share settings for a Vimeo Upload in FCPX, does it make a quicktime file and if so what are the settings? I tried to find yours (Bill Davis) on Vimeo to see, but couldn’t find it. I usually use 1280 by 720 p with a bit rate limit of 5 Mbits/second for Vimeo. I generate that in compressor and then upload. Maybe there is a better way.
