Activity Forums Adobe Premiere Pro Exporting Sequence to H.264. AVCHD footage.
  • Exporting Sequence to H.264. AVCHD footage.
    Posted by Sam Green on August 13, 2009 at 10:05 pm
    I am having big problems exporting a sequence to H.264. I will try and provide all the information. Please let me know if I have missed something.
    Problem:
    The sequence will not export cleanly. I have tried H.264, MPG 2 and MOV files none works. My preferred output would be H.264. I have exported files in this format before (taken on the same camera) without any trouble but this time there are jumps in the video (i.e. the picture jerks for a fraction of a second) and/or massive distortion of the whole image. The problem is not present when viewing the sequence.
    Should I reinstall?
    Having read lots of other posts (but none specifically about this) I’m wondering if I’ve just totally wasted my money – a lot of my money – and I need to cut my losses and get final cut studio.
    I would really appreciate help with this.
    Premiere version:
    4.1.0
    Computer:
    Mac OS 10.5.8
    2.8 ghz Intel Core duo
    4gb 800 mhz ddr2 sdram
    Camera:
    Panasonic HMC 151 (PAL version of HMC 150)
    Native file type:
    AVCHD
    Here are the properties of one of the video files:
    Type: MPEG Movie
    File Size: 343.0 MB
    Image Size: 1280 x 720
    Pixel Depth: 32
    Frame Rate: 50.00
    Source Audio Format: 48000 Hz – compressed – Stereo
    Project Audio Format: 48000 Hz – 32 bit floating point – Stereo
    Total Duration: 00:02:19:10
    Average Data Rate: 2.5 MB / second
    Pixel Aspect Ratio: 1.0
    Sequence details:
    Sequence 01
    1280 x 720
    00;17;41;26, 25.00 fps
    48000 Hz – Stereo
    Sequence 03
    1280 x 720
    00;04;55;17, 50.00 fps
    48000 Hz – Stereo
    (I’ve tried it both 50 and 25fps)
    Output:
    I have tried a variety of settings including:
    H.264 HDTV 1080p 25 set to 50fps
    H.264 Custom set to 50 fps
    Sam Green replied 16 years, 1 month ago 3 Members · 3 Replies
  • David Dobson
    August 24, 2009 at 9:58 pm
    Well, you said it worked before, so what’s changed since the last time it worked? Add any new software or updates? A quicktime update maybe?
    I do AVCHD to H.264 on a regular basis for Sony and I’ve never had a problem. But I am on a PC.
    Not sure FCP does ACVHD at all – or if it does it has to be converted to quicktime first – same with P2 and just about everything.
  • Florencia Davidzon
    July 30, 2010 at 7:00 pm
    Did you solve it? can you share how?
  • Sam Green
    July 30, 2010 at 10:03 pm
    Sorry Florencia I was not able to solve it. I was going so nuts with it I went out and bought FCP and re-edited the video on that…annoying
