Activity › Forums › Apple Final Cut Pro Legacy › Exporting self-contained movie makes ref movie
  • Exporting self-contained movie makes ref movie
    Posted by Niklas Wikman on March 20, 2009 at 9:49 pm
    This is a silly one – I’m trying to export a self-contained movie (for later bunk to tape). But when I check the “Make movie self-contained” the exports takes just a few minutes and the files is about 300 MB in size. It’s a 35 mins show in DV25. The movie should be way larger than 300 MB… The timeline is all rendered, so I really can’t figure out what to do??
    Niklas Wikman replied 17 years, 6 months ago 4 Members · 6 Replies
  • David Roth weiss
    March 20, 2009 at 10:30 pm
    You’d best check in Sequence>>Render All to insure that “Full” is checked. Then hit render, and then export a self contained QT.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Rafael Amador
    March 21, 2009 at 10:03 am
    [Dave LaRonde] “Export using Quicktime Conversion, in the exact same settings as the FCP timeline so QT doesn’t try to re-render anything.”
    QT Conversion re-compress everything whatever are your setting.
    Exporting with QT Player always re-compress, even if you export with the same parameters of your media.
    The only case that QT do not renders is when you use the “Save As..” function.
    rafael
    http://www.nagavideo.com
    (and here some clips for the friends: https://www.vimeo.com/2694745 )
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Andy Mees
    March 22, 2009 at 10:42 am
    Niklas
    Does this 300 MB file pay back correctly? Is your target hard drive full?
    If you are convinced that you’ve got all the settings correct (and choosing Export > Quicktime Movie w. Current Settings and Make Movie Self Contained ticked is all there is to it, you should not have to use any other method) and if its definitely not working correctly then you’ve probably got some hosed preferences. Trash them and try again.
    You can trash preferences manually, but using a simple tool to do the job makes it easy and offers some other advantages too (like backup and restore). One of the best FCP preference managers available is Jon Chappell’s excellent Preference Manager … and its free!
    Quit FCP, trash the prefs, relaunch FCP and try the export again .. post back
    Andy
  • Niklas Wikman
    March 22, 2009 at 8:55 pm
    Ooops, “Full” was NOT checked.
    Did that, re-rendered the sequence (20 min or so).
    Still gets out as a non self-contained movie. The other sequence (that did export correctly) did have Sequence -> Render only -> Full checked.
    Strange…
  • Niklas Wikman
    March 22, 2009 at 9:02 pm
    Thanks for the tip. Trashed the FCP prefs using the app, opened the project. Still small file when exporting QT movie as self-contained.
    Not sure how or what do to. I really really want to bunk the sequences as self-contained movies to tape, to make sure nothing goes wron (even if ref movies has worked fine in 99% of the time.)
    Niklas
  • Niklas Wikman
    March 22, 2009 at 9:18 pm
    (I tried to edit the previous post, but it did not stick, for some reason…)
    I selected all items in the sequnece, created a new one and pasted all items into that one. Re-rendered (not needed) and now the export to self-contained QT worked just fine.
    Thanks for all your help!
    Niklas – going to bed now
