Activity › Forums › DVD Authoring › Exporting scenes from DVD?
Posted by Pat Furrie on April 14, 2006 at 8:04 pmThe TV station I work for records DVD air checks of all of our newscasts. Periodically we get requests for a copy of a segment, and we’d like to send just that segment to them on DVD. It has been asked if there is a way to put the DVD into a computer, view the disc to find the in and out points we’re interested in (or something close to it) and then capture it back into the computer. That will then be burned to another DVD.
Yes, I know that we could just put a DVD player and recorder together and do it that way, but the people who do this want very clean in and outs to the segment.
Is there any software which would allow us to selectively grab sections of a DVD? Remember that these are DVDs to which we already own the content, so it completely legal.
Pat Furrie
WESH-TV, OrlandoWts(jmanz) replied 20 years, 4 months ago 8 Members · 15 Replies -
George Wing
April 14, 2006 at 8:55 pmI use Ulead’s VideoStudio 9 (soon to be version 10) to “Import from DVD” — it can import entire Titles, or specific Chapters. You could import the chapter(s), cut off the “excess”, and output one mpeg section. The software will even let you re-author the “kept” video into a new DVD.
Ulead also has other software that imports from DVD in the same manner — MovieFactory 4 and 5, and MediStudio Pro 8.
You could download their Trial version (keep in mind the Trials might not support Dolby Digital Audio, but the FULL versions support and encode Dolby Digital audio).
Regards,
George -
Pat Furrie
April 14, 2006 at 9:06 pmGeorge,
Thank you for the suggestion.
All of our DVDs have only one chapter, which means we’d have to import an entire 30 minute newscast in order to get just the relevant couple of minutes. Am really hoping to find something that can grab just the part of the disk we need without having to import anything extra. That should make it much faster (only having to import 2 minutes instead of 30).
Next?
Pat
Eric Pautsch
April 14, 2006 at 9:46 pmI use this:
https://www.videohelp.com/tools?tool=MPEG_StreamClip
But its mac only
Try Videohelp’s tool section and find anything you need:
Wts(jmanz)
April 14, 2006 at 10:36 pmPat,
Procoder from Canopus would allow you to import a dvd (which have VOB files) and while in the source tab scrub to the in and out point and set the target to then output the file in whatever format you want–even burning back out to dvd.
jim
Noah Kadner
April 15, 2006 at 2:40 amJust out of curiosity- how do they record to DVD? Does it first get captured and then exported to DVD or is it on a direct to DVD recorder? I ask because a far simpler system would be to capture to DV or at least direct to hard drive. Then you’d have a much much cleaner, much much easier to re-edit system. It could even be setup to run completely automatically and organize itself by date and time. DVD archiving is just that- archiving. If you are wanting to go back and re-use material often, DVD is IMHO worse than VHS because it’s not what it’s designed to do.
Noah
Pat Furrie
April 15, 2006 at 2:52 pmWhat version of ProCoder are you using? I downloaded the trial version (1.25.15.0), but VOB is not listed as a source type, and doesn’t even show up anywhere in help. Reading the online documentation for ProCoder Express, ProCoder 2.0, and ProCoder Statino, they each list “Source Formats” but DVD and VOB aren’t included.
Pat
Pat Furrie
April 15, 2006 at 3:00 pmThe DVD recording it done straight to DVD from a live feed of the newscast, recorded on a consumer stand-alone DVD recorder. This is primarly done for archiving of the newscasts, as you pointed out. It is simple and straight forward, without any need to have an intermediate step. On those occasions when we need to dub off something from a DVD, it could be many months from now. We don’t want to have that much programming sitting on a hard drive waiting to the possiblity of someone wanting a dub of it. And the use of the dub are presumed to be for non-broadcast use, so quality isn’t the issue, other than making clean in and out points to the segment.
Pat
Wts(jmanz)
April 15, 2006 at 4:03 pmPat,
The trial version of Procoder you are using did not support vob file conversion. Procoder 2 will transcode unencrypted dvd’s/vob files.
Jim
David Roth weiss
April 16, 2006 at 4:12 pmAnd, as Jim has determined, it can be run on either PC or MAC now.
Wts(jmanz)
April 16, 2006 at 6:12 pmIt gets even a notch better. When you boot up on the Mac side, you can create your content with LiveType/Final Cut/Motion 2/etc. If you format your PC to Fat, then you can read and write directly from with OS X to the Windows partition. I personally would format in NTFS (for a number of reasons, especially file size limitations of FAT), you can still read the files on the Mac side. However, with MacDrive6, you can read AND write to the Mac partition while in Windows. In other words, you take the content you created with Mac apps while in Windows and directly access them for use (in this case, to encode with Procoder). This eliminates the potential need to have an external drive to migrate files back and forth.
Jim
