Activity Forums Maxon Cinema 4D Exporting Scale data from AE to C4D
  • Exporting Scale data from AE to C4D
    Posted by Jm Chadillon on February 1, 2012 at 1:15 am
    Subject says it all. I need to export my scale keyframes (baked from an expression) to import into C4D applied to a null. Not sure if i should have posted this in the AE section. I figure most C4D people use AE for compositing anyways. Here goes.
    Ive tried C4D Exporter, and the pt_AE_to_C4D script with no avail.
    I can only see one issue and that’s that AE cant separate scale into XYZ like Cinema does. Or at least my AE wont let me. I see separate dimentions when i right click on scale but its greyed out.
    Any ideas?
    Nichole Kizer replied 12 years, 1 month ago 2 Members · 1 Reply
  • Nichole Kizer
    March 28, 2014 at 6:14 pm
    I’m having this same issue. I’ve got a video wall in the shape of a sphere in C4D that animates using Mograph. I’ve got everything baked. However, when I get back into AE none of my solids have any scale keyframes. Just Position. I see the keyframes baked in C4D, but they aren’t transferring over via the AEC. Using C4D 15 and AE CS6
