Activity Forums Adobe Premiere Pro Exporting r3d for compositing size issue
  • Exporting r3d for compositing size issue
    Posted by Chris Larsen on October 28, 2012 at 3:44 am
    I pulled up the properties tab and mimicked the frame size/rate but when I bring it back into premiere to double check and make sure that the frame sizes are the same, the prores version is about 11 percent smaller.
    I opened up the properties on the pro-res version and it matches the source for everything but codec, but there is a black border all the way around.
    Can anybody offer advice?
    Angelo Lorenzo replied 13 years, 11 months ago 2 Members · 1 Reply
  • Angelo Lorenzo
    October 28, 2012 at 9:15 pm
    What program are you using for the R3D to ProRes conversion?
    What us the resolution (width x height) of your footage? What is it when converted to ProRes?
    Also, what is the resolution of the Premiere Pro timeline? Sounds like you may have picked a preset that isn’t quite matching your footage. This is common if you’re working in 4K HD vs 4K full frame, and so on.
    Angelo Lorenzo
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
