Activity Forums Apple Final Cut Pro Legacy Exporting Quict time mov problems
  • Exporting Quict time mov problems
    Posted by Mark Bennett on February 14, 2009 at 2:41 pm
    I am trying to export a sequence from the fcp timeline to a quicktime movie all the footage is xdcam EX 1080 p25. I want this to be in lower quality as its a rough cut. The problem that I am getting is that the export is going out of sync by atleast 9 seconds. maybe you could help with this? thanks a million for help in the past.
    Kind regards
    Mark Bennett
    Rafael Amador replied 17 years, 6 months ago 2 Members · 3 Replies
  • Rafael Amador
    February 14, 2009 at 4:12 pm
    Hi Mark,
    I’ve never experienced that problem with EX-1.
    Had you tried Export to QT and QT Conversion?
    Rafael
    http://www.nagavideo.com
  • Mark Bennett
    February 14, 2009 at 10:58 pm
    Well I set my in and out point on the timeline of the sequence then went to Edit-Export..- Export quicktime movie. I unticked the “make self contained” box to speed up the process. Maybe I shouldnt have done this??
  • Rafael Amador
    February 15, 2009 at 2:07 am
    Well, then you are exporting a Reference Movie, but it shouldn’t be the audio delay, but this can be caused for different reasons (System limitations, a complicated time-line,..)
    Just check “Make Self-Contained” and make a test to see if the delay persists.
    Rafael
