Activity Forums Apple Final Cut Pro Legacy Exporting Quicktimes
  • Exporting Quicktimes
    Posted by Steve Rogalinski on September 5, 2010 at 4:01 am
    I am just getting back into the editing industry after a five year absence. I was extremely proficient on Media Composer, outputting to videotape.
    Now, I’m getting up to speed on Final Cut and I’m overwhelmed by exporting options and problems. Can someone point me to a place I can get help with Tapeless Workflow?
    Steve Rogalinski
    Rafael Amador replied 15 years, 12 months ago 3 Members · 6 Replies
  • Rafael Amador
    September 5, 2010 at 5:07 am
    Hi Steve,
    What kind of footage are you working with, and how do you expect to deliver your movies?
    rafael
    http://www.nagavideo.com
  • Chris Tompkins
    September 5, 2010 at 12:49 pm
  • Steve Rogalinski
    September 5, 2010 at 9:41 pm
    I am using a 1080i60 timeline. But in addition to 1080i60 footage, I have 1080i30 and 24fps footage. The biggest problem I’m having is stepping in the pans and zooms, particularly with the 24fps.
    Steve Rogalinski
  • Rafael Amador
    September 6, 2010 at 5:37 pm
    Your problem is not about exporting or codecs, but about basic knowledge on FC.
    You simply can not mix stuff stuff with different time-base in FC. Convert everything to a common one.
    Rafael
    [Steve Rogalinski] “1080i60 footage, I have 1080i30 “
    i30 and i60 is the same.
    rafael
  • Steve Rogalinski
    September 7, 2010 at 4:03 am
    Yes, I am definitely in need of more knowledge on FC. What is the best way to convert the footage?
    Steve Rogalinski
  • Rafael Amador
    September 7, 2010 at 5:19 am
    You need to convert your p24 stuff to p30; then you can put the p30 footage in a i60 sequence without problems.
    You can use Compressor or MPGStreamclip to go p24 to p30.
    Cheers,
    Rafael
