Activity Forums Apple Final Cut Pro Legacy Exporting Quicktime Ref causing FCP 5 to crash
  • Exporting Quicktime Ref causing FCP 5 to crash
    Posted by Bear Media on July 21, 2007 at 1:50 am
    I’m trying to export a quicktime reference file to run through the bitvise encoder on a long form show. The show is a 2 part 90 minute documentary captured at 8 bit uncompressed. The part 1 reference file exported beautifully, but part 2 won’t go.
    Here’s a short list of what I’ve tried so far (not in this order):
    – trashed prefs
    – made sure only part 2 timeline is open.
    – changed the export drive (the drive the file would be saved on)
    – safe booted and verified permissions
    – reinstalled the capture card drivers
    – restarted multiple times
    – played part 2 all the way through
    – checked, double checked, and triple checked drive connections
    It crashes every time. Any ideas?
    – Brad
    Neil Ryan replied 19 years, 2 months ago 2 Members · 1 Reply
  • Neil Ryan
    July 23, 2007 at 1:52 am
    Brad,
    Try exporting Video only (you don’t need Bitvice to do the audio, do you?)
    2 things to consider:
    Maybe try exporting Part 2 in several segments and joining them later (this will also help identify whether or not you have a faulty clip/render/file and if so, its location in the sequence.)
    Maybe try exporting Part 2 with just the base layer, then try with layer 2, etc, to establish what might be causing the problem.
    Good Luck.
    Neil Ryan
    Post Production
    The Pod Multimedia
    http://www.the-pod.com.au
