Activity Forums Apple Final Cut Pro Legacy Exporting Quicktime Movie Or Conversion
  • Exporting Quicktime Movie Or Conversion
    Posted by Espnetboy3 on May 10, 2006 at 4:24 am
    I posted on here a while ago asking the difference. Basically there really is no difference, as I see it regular quicktime is good for fcp to fcp because when its done rendering the export it has a fcp icon. Someone told me about photo-jpeg for a quick render and low compression size and I just want to say thank you because its amazing. I mean there are so many nonsense codecs that dont look near as good and take double the space and run poorly. Basically I dont get the video and none codec. I would think None meant no compression but people say animation codec is for the lossless output. Can anyone clear this up for me. Thanks all
    Espnetboy3 replied 20 years, 3 months ago 3 Members · 3 Replies
  • Liam Stephens
    May 10, 2006 at 10:49 am
    Haven’t noticed any differcen between the 2. only problems i have had with animation is exporting animation from Avid and bringing it into FCP, FCP doesn’t like it at all. I usually go None from Avid.
  • Lee Burrows
    May 10, 2006 at 2:49 pm
    Yeah Photo-Jpeg is a great codec! It is 2 to 1 which give you great storage space and a high quality look. You will hear a lot of people rave about how Digital video is better than analog beta which is technically true. However for the eye, Photo-Jpeg captured in from analog beta has much less artifacting and compression than Digital DV video captured in the DV/DVCPro NTSC codec.
    I wonder is it possible to capture DV video via firewire and in the capture settings have the quicktime compression setting be photo-jpeg instead of DV/DVCPro NTSC? Then DV might surpass analog beta.
    Lee
    G5 Mac OS X
    Dual 2.0 GHz
    FCP 4.5 HD
    XServe Raid 1 Terabyte
    G5 Mac OS X
    Dual 2.3 GHz
    FCP 5.02 Studio
    G-Tech G Raid 500 GBs
    2 – Lacie Drives 200 GBs
  • Espnetboy3
    May 10, 2006 at 7:10 pm
    I must say the dv/dvcpro ntsc codec looks very soft. Its not crisp at all and just looks slightly washed out and not sharp. It also takes up more space than the photo-jpeg which is kind of funny.
