Activity Forums Apple Final Cut Pro Legacy Exporting Quicktime from a Drop Frame source clip
  • Exporting Quicktime from a Drop Frame source clip
    Posted by Rob Larose on August 7, 2009 at 3:47 pm
    Good morning COWs!
    I’ve got a strange problem in FCP 5 that I’ve never seen before, but I’ve also probably never worked with dropframe source material before.
    When I set an in & out and export (or create a subclip and export) from a source clip that has DROPFRAME timecode, the timecode on the exported clip is wrong if it starts AFTER a minute-mark where the dropframe numbers are skipped. It matches what I see if I right-click the duration in the upper-right of the Viewer and set the source clip to “Non-Drop”.
    In other words, FCP seems to calculate the starting timecode of the exported clip as if the source clip were NON-drop. For example:
    MASTER CLIP A has timecode from 0:00:00;00 to 0:04:30;00 (duration of 4 and a half minutes)
    SUBCLIP 1 = 0:00:40;00 to 0:00:50;00 — timecode on the exported clip is right.
    SUBCLIP 2 = 0:01:15;00 to 0:01:30;00 — timecode on the exported clip starts at 0:01:14;28 (2 frames early)
    SUBCLIP 3 = 0:02:15;00 to 0:02:30;00 — timecode on the exported clip starts at 0:02:14;26 (4 frames early)
    Has anyone ever seen this behavior before? Is there anything I can do short of modifying the timecode manually after exporting?
    Thanks for any ideas y’all have got!
    –Rob LaRose
    Imaginary Forces
    Rob Larose replied 17 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
