Activity Forums Adobe After Effects Exporting Questions
  • Exporting Questions
    Posted by Steven Free on June 1, 2005 at 10:24 pm
    I’m currently working on a 90min. video in Premiere and a 6min. spiced
    up intro in After Effects which will have to be brought together to
    complete the overall video.
    Was wondering if I should export my 90 min video in Premiere and
    import it into AE to add it after my intro I’ve created in AE which
    will then be exported and then imported into a DVD authoring program
    or
    should I go the other route and export my 6 min intro in AE and import
    it into Premiere to add it before my video I’ve created in Premiere
    which will then be exported and then imported into a DVD authoring
    program?
    Also,
    What format does the intro need to be when exporting from AE and
    brought into Premiere?
    What format does the video need to be when exporting from Premiere and
    brought into AE?
    Should there be compression settings when exporting?
    Sorry to blast ya with all these redundant questions. I’m just finding
    it hard to find the answers to my questions. There are so many export
    options and different format choices to choose from. I’m just not sure
    what I’m supposed to do after I’m finished with the video and want to
    bring it into a DVD authoring program to burn a master DVD to give to
    the duplication studio.
    Steve Roberts replied 21 years, 3 months ago 4 Members · 4 Replies
  • Jeff
    June 2, 2005 at 1:13 am
    I’d say go from AE > Premier
    first off you’re dealing with transfering a 6 minute movie vs a 90 minute one. Premiere may be better at handleing/editing video vs AE that does animating and effects. It may be slower to try and render out a 96 minute movie in AE vs doing it in Premier.
    As for format I’m not a master of this. but I’ll say make sure it’s a “Lossless” formate (aka you don’t lose any quality) maybe either an AVI or a Quicktime.
    Here’s an atricle discussing the various pros and cons of some of the bigger/better codecs
    https://www.creativecow.net/articles/minut_manuel/crossplatform/index.html
  • Nicholas White
    June 2, 2005 at 1:37 am
    Hey,
    AE to Premiere, make sure to use something like the Quicktime Animation codec for best quality.
    Once you bring in the .mov file into Premiere and everything is ready to go, simply render out an .m2v and .m2a file to bring into your DVD authoring app. Saves both time and hard drive space.
    Take care,
    Nick
  • Steven Free
    June 2, 2005 at 8:12 am
    When exporting from After Effects. I see the options AVI., DV Stream., and MPEG-4., and a few others. So should I export it as a AVI. file? If so, the AVI video settings have DV/DVCPRO-NTSE , None and a few others. What should it be set to and should it be set to best quality?
    Also, what would these other export options (AVI., DV Stream., and MPEG-4.) be used for as well as the video settings?
    Thanks so much..
  • Steve Roberts
    June 2, 2005 at 10:49 am
    Read the manual under “make movie” and “render queue”.
    Steve
