Activity Forums Adobe Premiere Pro Exporting Questions
  • Exporting Questions
    Posted by Steven Free on June 1, 2005 at 10:25 pm
    I’m currently working on a 90min. video in Premiere and a 6min. spiced
    up intro in After Effects which will have to be brought together to
    complete the overall video.
    Was wondering if I should export my 90 min video in Premiere and
    import it into AE to add it after my intro I’ve created in AE which
    will then be exported and then imported into a DVD authoring program
    or
    should I go the other route and export my 6 min intro in AE and import
    it into Premiere to add it before my video I’ve created in Premiere
    which will then be exported and then imported into a DVD authoring
    program?
    Also,
    What format does the intro need to be when exporting from AE and
    brought into Premiere?
    What format does the video need to be when exporting from Premiere and
    brought into AE?
    Should there be compression settings when exporting?
    Sorry to blast ya with all these redundant questions. I’m just finding
    it hard to find the answers to my questions. There are so many export
    options and different format choices to choose from. I’m just not sure
    what I’m supposed to do after I’m finished with the video and want to
    bring it into a DVD authoring program to burn a master DVD to give to
    the duplication studio.
    Craig Howard replied 21 years, 3 months ago 2 Members · 6 Replies
  • Craig Howard
    June 2, 2005 at 3:40 am
    program?
    >>>>>Export from AE and import it into Premiere ( especially for that length of project)
    Also,
    >>>>>>Same as the Project. (DVavi lossless will be the best you can acheive)
    brought into AE?
    >>>>>>Same as the project ( DVavi un compressed will be best)
    >>>>>>Better to not use compression (Do not recompress is the setting)
    >>>>>Once you have a finished ( rendered ) movie. Ask your duplication house how they want it. It will be a huge (massive) file and you will have to find a way to get it to them.
    Craig
    Shooter Film Company
    Auckland
    New Zealand
    (Premiere Pro 1.5 / Matrox TRX100 XTreme Pro)
  • Steven Free
    June 2, 2005 at 8:08 am
    When exporting from After Effects. I see the options AVI., DV Stream., and MPEG-4., and a few others. So should I export it as a AVI. file? If so, the AVI video settings have DV/DVCPRO-NTSE , None and a few others. What should it be set to?
    Also, what would these other export options (AVI., DV Stream., and MPEG-4.) be used for as well as the video settings?
    Thanks so much..
  • Steven Free
    June 2, 2005 at 8:14 am
    Also, when exporting from AE it should be set to best quality correct?
  • Steven Free
    June 2, 2005 at 9:13 pm
    Thanks for all the help Craig.
    Can I export my complete video from Premiere into an avi un-compressed format and bring that avi file into an DVD authoring program or does it have to be a MPEG-2 file that’s brought into a DVD authoring program?
  • Craig Howard
    June 2, 2005 at 9:18 pm
    Yes – there are a lot of options for exporting from AE.
    The trick is to match the project settings (AE & PremPro) and hopefully you set up the project settings with something appropriate to your end use in the first instance.
    I do everything DV avi (lossless/uncompressed/best quality)including export final movie. I make other media ( QTime etc) from the fully rendered movie.
    A lot of the options you mention are compressed in some way or other.
    Craig
    Auckland
    New Zealand
  • Craig Howard
    June 4, 2005 at 10:24 pm
    Might depend on the authoring program but I just drag the avi file in and let the authoring program code it. Possibly there are better (quicker) ways but it works for me.
