Activity Forums Apple Final Cut Pro Legacy exporting QT data rate/fps error
  • exporting QT data rate/fps error
    Posted by Todd Heyman on June 24, 2010 at 7:04 pm
    I’m exporting a 00:60 23.98 fps sequence using quicktime conversion. It is giving me the best picture quality vs compressor or MPG streamclip on this project.
    I am setting the export for an H264 at 23.98 fps with a data rate limit of 1800 kbps. The file should be about 16 mpgs. Yet every export makes the framerate 4.02 fps with a date rate limit of 5600k so the file is almost 40mgs.
    anyone know why this would happen?
    Tom Wolsky replied 16 years, 3 months ago 2 Members · 3 Replies
  • Tom Wolsky
    June 24, 2010 at 7:51 pm
    This doesn’t make sense. If you export to QuickTime Movie you should get a file that matches exactly the sequence settings that you’re exporting. You then take that to Compressor.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Todd Heyman
    June 24, 2010 at 8:14 pm
    im exporting with quicktime conversion not quicktime movie
  • Tom Wolsky
    June 24, 2010 at 8:48 pm
    Don’t do that. Do it right using Compressor.
    All the best,
    Tom
