Activity Forums Apple Final Cut Pro Legacy Exporting problems with smoothcam filter
  • Exporting problems with smoothcam filter
    Posted by Matt Henry on April 30, 2010 at 8:00 pm
    I have searched for an answer online and haven’t found a solution yet. I’m trying to export my video from FCP and when I play the exported file I see the same error every time where it’s very jittery with the smoothcam filter as though its not being applied in the export.
    The footage is from an AVCHD Canon camera and I have exported using FCP and Compressor using .H264, Pro Res, and a self-contained Quicktime export to no avail. This is the first project where I’ve had to use the smoothcam filter.
    It might be worth mentioning that one clip with smoothcam is working as it should in the export.
    Matt Gibbs replied 16 years, 2 months ago 3 Members · 3 Replies
  • David Roth weiss
    May 1, 2010 at 2:27 pm
    Export a self contained QT using Export>>Quicktime Movie at current settings. Then use that file in Compessor to make your h.264 files etc.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Matt Henry
    May 3, 2010 at 2:59 pm
    Thank you! That solved the problem. It’s a little confusing because when you export the the self contained QT it has the shakiness problem until you run it through compressor.
  • Matt Gibbs
    July 23, 2010 at 12:09 pm
    Hi
    I’m currently having the same problem but I’m unfamiliar with the software, especially compressor. Is there any chance you can break it down step-by-step for me?
    I would really appreciate it.
    Matt
