Activity Forums Adobe Premiere Pro Exporting problems. Please help..
  • Exporting problems. Please help..
    Posted by Ari Schwartz on December 26, 2009 at 10:33 am
    While using adobe premiere cs4 I export my project as mpeg4. then it opens the NTSC, 176×144, 15 fps.. It opens in adobe encoder and then i hit queue. after it is done it open up in “adobe device central” and that’s where i’m lost. All i want to do is upload my video on to Youtube.com. What am I doing wrong??
    Ari Schwartz replied 16 years, 8 months ago 3 Members · 5 Replies
  • Vince Becquiot
    December 26, 2009 at 7:09 pm
    Export to Flash f4v, 29.97, same field order as the original, or progressive if needed. Export at the original resolution up to 720P for HD.
    Set the bit rate between 3 and 6 Mb/s depending on how long the video is and your connection speed. I think YouTube still allows up to 2 GB in file size.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Ari Schwartz
    December 26, 2009 at 9:44 pm
    Which F4V should i use? Here are some of my options:
    Web Large NTCS Source [flash 9.0 r115 and Higher]
    Web Large PAL Source [flash 9.0 r115 and Higher]
    Web medium [flash 9.0 r115 and Higher]
    HD 720p[flash 9.0 r115 and Higher]
    HD 1080p[flash 9.0 r115 and Higher]
    What is best for YOUTUBE???
  • Ari Schwartz
    December 26, 2009 at 9:47 pm
    Oh, also, the audio bit rate automatically starts at 128. Is that good?
  • Tam Perl
    December 27, 2009 at 12:46 am
    YouTube has a list of recommended formats. But it really doesn’t make too much difference. You should come out of Premiere with the best resolution you can, say as a H264 .mov file, then upload it to YouTube. Let the YouTube website do the conversion to Flash. It’s that simple.
  • Ari Schwartz
    December 27, 2009 at 9:15 am
    Ive tried at least 10 different formats for exporting my project to be uploaded on youtube and nothing has worked fully. The closest i came to a full on video was when the format was at: “H.264 youtube widescreen HD” unfortunently the video was slower than the audio and the audio had glitch-like breaks in it…
    How do I find my what my starting media was? This is really one of my 1st videos, but i’ve put at least 10 hours into it and still havn’t figured out how to export a project worthy of going on youtube. How do all those people do it? I’m really not that bad with computers. I’m an audio engineer, but when it comes to videos im just LOST!
    Where can I find the info that you need, in order to help me? Do you need my video camera specs?
    After highlighting one of my video clips I hit properties and this is what I got:
    Type: MPEG Movie
    File Size: 36.1 MB
    Image Size: 720 x 480
    Pixel Depth: 32
    Frame Rate: 29.97
    Source Audio Format: 48000 Hz – compressed – Stereo
    Project Audio Format: 48000 Hz – 32 bit floating point – Stereo
    Total Duration: 00;00;33;00
    Average Data Rate: 1.1 MB / second
    Pixel Aspect Ratio: 1.2121
    hope this helps in someway..
    Here is my audio clip specs:
    Type: MP3 Audio
    File Size: 3.8 MB
    Source Audio Format: 44100 Hz – compressed – Stereo
    Project Audio Format: 44100 Hz – 32 bit floating point – Stereo
    Total Duration: 00:02:45:06444
    Average Data Rate: 23 KB / second
