Activity Forums Adobe Premiere Pro Exporting problems in Premiere Pro CC
  • Exporting problems in Premiere Pro CC
    Posted by Adrian Doidge on July 15, 2016 at 12:30 am
    Hi.
    The past few projects I have worked on with Premier have been causing some major and mysterious problems when it comes to both the rendering and export stage of the workflow.
    Each time I export the project I receive a warning with very little detail that is closing down the whole program.
    All the files used are saved natively to my mac, and the export is also being saved natively.
    My machine details are as follows:
    Model Name: iMac
    Processor Name: Intel Core i7
    Processor Speed: 3.5 GHz
    Number of Processors: 1
    Total Number of Cores: 4
    L2 Cache (per Core): 256 KB
    L3 Cache: 8 MB
    Memory: 16 GB
    I have been sure to update my Premiere Pro application from CC, and recently uninstalled and reinstalled the App.
    I’m not quite sure what’s going wrong or how to trouble shoot the project.
    I’ve included screen shots of my export settings – which are fairly standard so far as I know.
    All feedback and suggestions will be most welcome.
    Thank you.
    Dan Powers replied 7 years, 5 months ago 5 Members · 10 Replies
  • 10 Replies
  • Jon Doughtie
    July 15, 2016 at 12:55 pm
    Your screen shots didn’t make the journey, I’m afraid.
    Tell us more about your system storage as well. Media on different drives from the OS? That sort of info.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2015.02 (as of 6/2016)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
  • Adrian Doidge
    July 18, 2016 at 5:37 am
    Hi Jon.
    Sorry the screen shots didn’t make it to the post.
    None of the media I’m using is on a different drive. Everything is saved natively to the machine, sitting in a neat set of files on the OSX Desctop.
    The machine itself runs pretty well –
    Processing: 3.5 GHz Intel Core i7
    Memory: 16 GB 1600 MHz DDR3
    Graphics: NVIDIA GeForce GTX 780M 4096 MB
    I’m not sure what else I can tell you.
    Thanks for your time.
  • Adrian Doidge
    July 18, 2016 at 5:38 am
  • Adrian Doidge
    July 18, 2016 at 5:39 am
  • Adrian Doidge
  • Adrian Doidge
    July 18, 2016 at 5:40 am
  • Ht Davis
    July 19, 2016 at 10:04 am
    Do you have Adobe Media Encoder installed? Try Queuing the video out to media encoder. Also, you might start a clean project, import your old project into it, save it new, clear the cache, save again, close, open again and then export the sequences. Sometimes the cache files get too big or too heavy for it to process correctly, and in trying to call up more room or more memory start points, it fails. Check how much ram you allocated to the program in your preferences.
    Also, without adobe media encoder, some video formats will look okay in projects, but never render out.
  • Adrian Doidge
    July 20, 2016 at 1:11 am
    Thanks HT Davis.
    You’ve given me quite a lot to look at. I’ll try this later today, and let you know the outcome. 🙂
  • Fereshteh Tavakoli
    March 31, 2019 at 3:24 pm
    Hello buddy
    I suggest you to change the sequence range in export settings to “entire sequence”
  • Dan Powers
    April 1, 2019 at 5:46 pm
    Try changing to software only, open CL, and Metal as alternate tests for rendering engines.
