Activity › Forums › Apple Final Cut Pro Legacy › Exporting Problem – Aspect Ratio
  • Zane Barker
    July 19, 2009 at 5:51 am
    [Yianni Mathioudakis] “I have a sequence that I’ve finished editing in FCP that I’m ready to export using Compressor. However, when I export I’m getting that “squished” look”
    [Yianni Mathioudakis] “I still have not figured out a solution, or what I’m doing wrong”
    Cant say what you are doing wrong as we don’t know what your settings are in compressor.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Neil Sadwelkar
    July 19, 2009 at 11:03 am
    I tried a direct export in FCP with Export > Using Quicktime Conversion. But I’m not seeing the ‘squish’ you’re seeing. There must be some Compressor setting that’s causing this squish. Probably in the ‘Geometry’ section where sizing is set.
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    FCP Editor, Edit systems consultant
    Mumbai India
  • Yianni Mathioudakis
    July 19, 2009 at 3:24 pm
    Hey Neil,
    I tried a direct export in FCP with Export > Using Quicktime Conversion too, and it looks perfect! So it’s obvious I’m doing something wrong in Compressor. So now I have a couple questions.
    1. Is it okay to use QT Conversion for all my exports? Or should I always use Compressor
    2. I’m using H.264 because I hear that’s the best for trimming file size while retaining good quality. Is that recommended?
    Here’s a summary from my settings in Compressor:
    Description: QuickTime H.264 video with PCM audio at 48 kHz. Settings based off the source resolution and frame-rate.
    File Extension: mov
    Estimated file size: unknown
    Audio Encoder
    16-bit Integer (Little Endian), Stereo (L R), 48.000 kHz
    Video Encoder
    Format: QT
    Width: 1280
    Height: 720
    Pixel aspect ratio: Square
    Crop: None
    Padding: None
    Frame rate: (100% of source)
    Frame Controls: Automatically selected: Off
    Codec Type: H.264
    Multi-pass: On, frame reorder: On
    Pixel depth: 24
    Spatial quality: 75
    Min. Spatial quality: 25
    Key frame interval: 24
    Temporal quality: 50
    Min. temporal quality: 25
    Thanks again!
    Yianni
  • John Fishback
    July 19, 2009 at 7:07 pm
    In general, Compressor will do a much better job of scaling than QT. You need to turn Frame Controls on and select Best for the scaling quality. Also, I recall a couple of posts on the best file to provide for upload to Vimeo and You Tube using Compressor. A search will turn them up.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Zane Barker
    July 19, 2009 at 8:49 pm
    Try trashing your compressor preference file and then try it again.
