Activity Forums Apple Final Cut Pro Legacy Exporting problem
  • Exporting problem
    Posted by Arvid Utas on August 13, 2012 at 8:15 pm
    Hello people, how are you?
    This is my problem:
    I have a 5gb large h264 .mp4 file that I need to do some minor changes to. When I import it into FCP the program says “General error” and then “Error: out of memory” and I cant see the project in the canvas. Still I managed to do what I needed to do blindly and I don’t know if the memory issue matters for my problem. What happens is that when I have exported the project (Export – Quicktime movie) it doesn’t play smoothly. The camera movement appears jittery.
    What can I do to avoid this?
    Help would be rewarded with great appreciation and good karma!
    Cheers.
    Shane Ross replied 14 years, 1 month ago 3 Members · 2 Replies
  • Jerry Wise
    August 13, 2012 at 8:29 pm
    convert your file to prores422 using mpeg streamclip and then edit.
  • Shane Ross
    August 13, 2012 at 9:23 pm
    Or use an editing app that works with that file format natively, like Adobe Premiere Pro
    Shane
    Little Frog Post
