Activity Forums Adobe Premiere Pro Exporting part of sequence while maintaining relative frame-number
  • Exporting part of sequence while maintaining relative frame-number
    Posted by Christian Bechmann on April 24, 2009 at 11:09 am
    Hi.
    I have a project in Premiere CS3. I would like to export that to TGA framestack for further processing.
    Usually I would export with file->export->export movie (or media encoder).
    later, I find an error in my sequence (new clip, spelling error etc.) so I would like to re-export that part only, but still maintaining the relative frame numbers (so that i would fit with the rest of the export).
    It appears to me that the exported frames always start with 0, no matter what i do with sequence markers or the work-area bar.
    What am I missing? Its probably just a checkbox somewhere, but i cannot find it. Please help 😉
    Thanks in advance
    – Christian
    Christian Bechmann replied 17 years, 4 months ago 2 Members · 2 Replies
  • Eddie Lotter
    April 25, 2009 at 5:01 pm
    [Christian Bechmann] “What am I missing?”
    Unfortunately you are not missing anything as far as PPro’s capabilities are concerned. The behaviour you are observing is as designed.
    This idea has come up before, I recommend you submit a feature request to Adobe.
    Until then, export the changed frames to a separate folder and use Adobe Bridge or other utility to batch rename the files.
    Cheers
    Eddie
  • Christian Bechmann
    April 25, 2009 at 6:19 pm
    Thanks for the reply.
    To bad this feature is not supported, I’ll have to continue to use renamers to fix it.
    I’ve followed your advice and requested it as a feature.
