Activity › Forums › Adobe After Effects › exporting pal dv from afx to final cut pro still requires a render?
  • exporting pal dv from afx to final cut pro still requires a render?
    Posted by Simon Tyszko on September 10, 2009 at 8:28 pm
    Im sure this is something so basic, yet i have checked and double checked my presets and both appear to be identical, yet when exporting some pal dv footage from afx and into fcp, i still have to render the sequence to see the video, redline all the way?
    so, im on mac
    im using in AFX
    PAL D1 presets also tried D1 square
    double checked
    720x 576
    best quality
    25fps
    RGB
    im using in FCP
    DV PAL 48K
    HELP
    thanks
    s
    Simon Tyszko replied 17 years ago 59,778 Members · 2 Replies
  • Simon Tyszko
    September 10, 2009 at 10:37 pm
    hello dave
    i thought you had it there for a second, but rechecking the presets on this CS3 version, the composition preset im using is described as PAL D1/DV
    and the output settings are quicktime PAL DV 48khz
    yet still i need to render sequence in FCP?
    thanks for your reply
    simon
  • Simon Tyszko
    September 10, 2009 at 10:55 pm
    oh no this has been going on for months….curious
