Activity › Forums › Adobe After Effects › Exporting out alpha channel
  • Exporting out alpha channel
    Posted by Kangling Teo on June 6, 2010 at 1:48 pm
    Hey,
    I’ve made a title sequence that I’m going to put onto live footage in FCP, so I exported out the sequence in alpha.
    Problem is, when I export it out, the lens flare in my sequence is kind of screwed up and my text lost their colours.
    Any ideas how to fix it?
    Additional info:
    Lens flare layers in Add transfer mode.
    Used colorize from Hue/Sat for the colors on text/lens flare
    Used animation compressor
    Thanks in advance!
    Michael Lange replied 16 years, 3 months ago 3 Members · 2 Replies
  • Tudor “ted” jelescu
    June 6, 2010 at 4:21 pm
    Here’s a great tutorial that will not only help you composite a lens flare, but give you some pointers on compositing in general:
    https://library.creativecow.net/rollason_ben/lens-flare/1
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
    http://www.ennstudio.ro
  • Michael Lange
    June 6, 2010 at 9:04 pm
    When you export with an alpha, make sure you set the alpha channel type correctly in FCP. Ctrl-click the clip in FCP and choose ‘Item Properties’ Set the alpha channel type to whatever is appropriate for your clip.
    I would recommend exporting anything out of AE with a “straight alpha” since some other NLE, such as Avid, don’t easily support premultiplied alpha channels.
    Michael Lange
    Producer/Editor
    https://www.langetv.com/blog
