Activity › Forums › Creative Community Conversations › Exporting only a portion or section of your timeline in FCPX
  • Exporting only a portion or section of your timeline in FCPX
    Posted by Rudy Diaz on July 2, 2011 at 5:59 am
    Can I export only a portion of the timeline in FCPX . Sometimes I need to export just a section of my time line so I can review it or even bring into another software for additions of other effects. Is this possible . I had heard somewhere it was not.
    thanks
    Rudy
    Jeff Neria replied 14 years, 8 months ago 6 Members · 6 Replies
  • Paul Figgiani
    July 2, 2011 at 1:34 pm
    Rudy – send to Compressor (Share/Send to Compressor). Then set in and out points in the Preview Window.
    -paul.
  • Manfred Kraus
    July 3, 2011 at 1:42 pm
    I guess “compound clips” are what you are looking for.
    Izzy made a good tutorial for this: https://www.izzyvideo.com/final-cut-pro-x-tutorial/17-compound-clips-in-final-cut-pro-x/
    signature
  • Jeff Neria
    October 15, 2011 at 11:53 pm
    Has anyone figured out how to do this or conclusively determined that it just can’t be done without compressor? I watched the video posted by MK MK, but once you get the section you want packaged into a compound clip, I still don’t really see how to export just that clip.
    I need to break up a timeline so that i can have a 3.5 hour video span across two dvds.
    After finding a breakpoint, then breaking each section into a compound clip, it wasn’t immediately, or eventually, obvious how to export just the selected clip. So now i have compound clips, clip A and clip B. I copied clip B into another project hoping i could just split the first project into two, klunky for me but workable.
    The problem with that is that I need to burn in timecode, so when i copy clip B to the new project, the timecode generator starts fresh in the new timeline with 0. I can’t figure out any way to make the timecode generator start with where it left off from clip A.
    Any ideas? In FCP7 i think the setting was in the timeline settings and possibly also in the effect properties itself. In X i see no way to do this.
  • Matt Surf
    January 23, 2012 at 10:36 am
    I’ve had the same problem and, although far from ideal, I’ve taken to cutting and pasting the desired sections into separate projects and exporting from there!!
  • Steve Connor
    January 23, 2012 at 10:48 am
    [Matt Surf] “‘ve had the same problem and, although far from ideal, I’ve taken to cutting and pasting the desired sections into separate projects and exporting from there!!”
    That’s what I do, it’s not exactly a big deal to create a separate project for it.
    Steve Connor
    “FCPX Agitator”
    Adrenalin Television
  • Jeff Neria
    January 23, 2012 at 5:30 pm
    The cutting and pasting would work for me to, except that I need to burn in timecode and there is no way to create an offset ( for the 2nd and subsequent projects) with the built in timecode generator. And last i’ve tried and heard, the generator created in motion does’t work for 24 fps media.
