Activity Forums Apple Final Cut Pro Legacy exporting NTSC as PAL
  • exporting NTSC as PAL
    Posted by Tim Brunsden on February 18, 2009 at 2:53 pm
    Hi – just wondering the best way to export some NTSC footage I have as a PAL movie? This is the only time I’ve needed to do this so I was hoping to find a way to do it rather than purchase the Natresse plug-in (which i think would do it). I’ve edited the footage onto a PAL timeline, exported as a PAL movie but when I burn to DVD jumps consistently. Any help would be really appreciated.
    Many thanks
    Tim
    David Keslick replied 17 years, 7 months ago 4 Members · 4 Replies
  • Walter Biscardi
    February 18, 2009 at 4:52 pm
    Nattress Standards Converter.
    Teletream Episode
    You can’t simply drop NTSC footage into a PAL timeline and render, it doesn’t work that way.
    Some folks say Compressor does a good job with this, I wasn’t impressed.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • John Pale
    February 18, 2009 at 6:20 pm
    [walter biscardi] “Some folks say Compressor does a good job with this, I wasn’t impressed”
    I used to be in this camp, until recently. I had a clip I needed to convert that had graphics in it. No matter what I did, the Nattress clip was too soft. The one I did in Compressor 3, with the Frame controls set to “Better” was razor sharp…identical to the original and the motion was perfect. Oddly enough, the test I did with “Best” was not as good. I guess the algorithm it uses for Best is not appropriate for all types of footage.
    Of course the render time was horrifically long (only a G5 Dual 2ghz) but for a 3 minute piece it was worth the wait.
    If its a short piece, I would definitely give Compressor a try…but if its lengthy, it might not be practical.
  • Tim Brunsden
    February 19, 2009 at 11:31 am
    OK – thanks – I’ll give it a go.
  • David Keslick
    February 20, 2009 at 11:48 pm
    You may also want to check out. DVFilm Atlantis for converting NTSC to PAL.
    Hope this is helpful,
    Dave Keslick
    DVFilm.com
