Activity › Forums › Apple Final Cut Pro Legacy › Exporting my project to a P2 card
  • Exporting my project to a P2 card
    Posted by Chuck Purnell on August 27, 2009 at 2:36 pm
    I shot a piece on my P2 camera at work. I did the editing with FCP at home. Now I need to export the project and put that onto a P2 card so I can bring it work and ingest it into our server system. Got all that?
    Our Panasonic Rep said I could simply run a FW cable out of my computer to FW jack on my P2 reader and just drag the file over. Even when I put the reader in 1394 mode for the Firewire, my computer didn’t recognize the p2 reader.
    I exported a QT File and am guessing that will need to be converted to the P2 format of .MXF?
    Now I will add, that yesterday I got this to work but I had some issues. in FCP, I selected Pint to Video. My picture came up on my reader screen (AG-HPG20). I pressed record on the reader and play on the computer screen and everything was there, playing back fine and recording to the card. When I played the clip back, I noticed it was dropping frames every few seconds which made my video look like it was stuttering.
    Someone mentioned some software called Raylight that will allow me to convert a QT file into a .MXF file. I have yet to try that.
    Cre8tive Minds Entertainment, LLC
    Dennis Radeke replied 17 years, 1 month ago 6 Members · 8 Replies
  • 8 Replies
  • Mark Maness
    August 27, 2009 at 2:57 pm
    Why not just copy the file to an external hard drive?
    You can get a small Western Digital USB drive for less than $100 that will do just fine for transferring data.
    _______________________________
    Wayne Carey
    Schazam Productions
    https://web.mac.com/schazamproductions
    schazamproductions@mac.com
  • Chuck Purnell
    August 27, 2009 at 3:40 pm
    Well technically I did put the file on my 8gb thumbdrive but its still in Quicktime format. So I never tried ingesting that file into our system. I am almost positive for me to ingest footage into our server system at work, it needs to be in P2 format. Second thought, I take that back because before we switched to P2 we were using Beta SX tapes and ingesting them just fine. Now another thought would be to get another hard drive like you mentioned then format that drive to P2. I wonder if that would work but that goes back to my original thought that the original file would still be in a quicktime format unless its converted somehow to P2 format right?
  • David Roth weiss
    August 27, 2009 at 4:11 pm
    [Chuck Purnell] “Well technically I did put the file on my 8gb thumbdrive but its still in Quicktime format. So I never tried ingesting that file into our system. I am almost positive for me to ingest footage into our server system at work, it needs to be in P2 format.”
    Chuck,
    Sorry, but this isn’t making sense.
    What’s the deal at work, it the server a Windows machine incapable of playing DVCProHD? If so, you can simply transcode the file to ProRes. There is a Windows decoder for Quicktime built in to the latest version of Quicktime or available standalone on the Web as a free download if the latest QT version is not installed.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Mark Maness
    [Chuck Purnell] “Now another thought would be to get another hard drive like you mentioned then format that drive to P2. I wonder if that would work but that goes back to my original thought that the original file would still be in a quicktime format unless its converted somehow to P2 format right? “
    Nice idea… but will not work. You still have the Quicktime wrapper. You’ll need something like this to do what you need.
    https://opencubetech.com/page53/XFConverter
    Can you tell us more about your server? This will help us help you.
    Wayne Carey
    Schazam Productions
  • Steve Eisen
    August 27, 2009 at 4:47 pm
    In addition to the answer I gave in the P2 forum, print to tape will work via firewire. For DV, you will get audio and video but no timecode. DVCPro HD is just a video stream. There will not be audio but you will get timecode.
    If you need to get this done, you will need Raylight.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Nicole Haddock
    August 27, 2009 at 6:50 pm
    Do you have Adobe Premier CS 3 or 4? It’s a bit of a workaround, but you can import a self-contained quicktime file of your FCP project into Premier and then output it to an .MXF file. I can’t remember if it makes the contents folders, but it does work. I had to use this function in Premier when I was working with filmmakers on a PC with CS3 and we couldn’t figure out how to export a good looking, full res quicktime from footage shot on the HPX-500. FCP saw the folder and ingested it like a quicktime, ala the usual Log and Transfer P2. I was pretty amused that it all worked, but it does.
    If you need more info, I can look at Premier and try and remember how I did it.
  • Steve Eisen
    August 27, 2009 at 7:34 pm
    Premiere indeed creates a Contents folder.
    Steve Eisen
    Board of Directors
  • Dennis Radeke
    August 28, 2009 at 11:59 am
    If you’re using CS4, you should import your FCP project into Premiere Pro and then you’ll have independent clips being put back as MXF.
