Activity › Forums › Adobe Premiere Pro › Exporting my 720p video = misery!
  • Exporting my 720p video = misery!
    Posted by Georgina Lord on June 26, 2009 at 6:53 pm
    I’m really struggling trying to get a decent output from my Premier Pro (CS4) project. I would like to export the project as a H.264/MP4 file, but just about every media encoder configuration I have tried results in video playback which isn’t as smooth as I am expecting.
    My project is a 1280x720p 30fps (square pixel) video, which I want to encode as the same. I’ve even tried going up to a video bitrate of 35mbps with pretty average results (see settings below). The video never plays as smooth as it does when I preview it in Premier.
    Here are the export settings I am using in Adobe Media Encoder:
    Format: H.264
    TV standard: NTSC
    Frame Width: 1280
    Frame Height: 720
    Frame Rate: 30
    Field Order: Progressive
    Pixel Aspect Ration: Square pixels
    Profile: Main (I don’t understand what this setting is)
    Level: 5.1 (Again, I’m not sure what this setting does)
    Bitrate Encodng: VBR 1 pass
    Target Bitrate (MBPS): 30
    Maximum bitrate (MBPS): 35
    Advance Settings (set keyframe distance): I have left this unchecked (not sure what settings to use, if any)
    MULTIPLEXER: MP4
    For a video project that is 2 minutes 54 seconds long, the above settings result in an MP4 file that is around 350 megabytes in size. But again, it doesn’t play as smoothly as the preview within Premier itself, which is disappointing.
    My PC specs are as follows:
    Quad core 2.6ghz
    4 gig RAM
    2x800mb hard drive
    Nvidia 8800 gfx
    Windows XP professional 64bit
    I’m pretty new to editing HD video so I could be doing something very wrong. I’d appreciate some advice on the settings I should try using to export the project as an H.264 file please. The more detail (in plain English!) the better.
    By the way; I did try to export the video as Microsoft AVI with a view to perhaps re-encoding that in a 3rd party program, however after about 5 hours of waiting for the video to encode, I gave up, suspecting problems. If I export as MS uncompressed avi, the resultant file seems to play only the audio.
    Thanks for reading.
    G.
    Alfred Ruffner replied 17 years, 2 months ago 4 Members · 3 Replies
  • Eric Jurgenson
    June 26, 2009 at 8:39 pm
    I typically use the Quicktime version of H.264 with pretty good results. I think the straight H.264 encoder is primarily for Blu-ray encoding.
  • Jeff Brown
    June 26, 2009 at 9:54 pm
    I’m not an expert on H.264, but I think that high a bitrate might be too much for a desktop processor to decode. You might try knocking it back a lot (like to 2 Mbps) and see what the playback is like.
    -jeff
  • Alfred Ruffner
    July 31, 2009 at 6:42 am
    If you have 720 to 30p editing and want to retain a good render HD. The best alternative that gives us Adobe Media Encoder to export is in h.264 blu-ray 1080i.
    The result is very good. Minimum loss, Almost negligible compared to other configurations.
    Format: H.264 blu-ray
    Quality: 5
    Frame dimensions: 1920 x 1080
    Frame rate: 29,97 frame drop
