Activity Forums Adobe Premiere Pro Exporting MXF with DVCPRO 50 codec
  • Exporting MXF with DVCPRO 50 codec
    Posted by Dean Anderson on September 13, 2012 at 7:42 pm
    I have a station that is just now accepting files and the only way they will accept SD files are in the MXF wrapper with the DVCPRO 50 codec. It looks like if you select P2 Movie, it will let you choose a that codec, but then the files all come out in a folder called “CONTENT,” and I need one single file to upload. Is there any way to generate this type of file out of PPro CS6?
    Chris Borjis replied 14 years ago 2 Members · 3 Replies
  • Chris Borjis
    September 13, 2012 at 8:59 pm
    dig through the folders and find the .mxf file i think.
    hopefully the audio is not in a separate file.
  • Dean Anderson
    September 14, 2012 at 12:49 pm
    The audio and video are in separate files and the video files are separated. I think they cut each file at 4gb. There must be some other way to do this.
  • Chris Borjis
    September 14, 2012 at 6:55 pm
    If thats the format they want, they “should” be able to accept
    it the way it’s made.
    See if you can zip/archive the export folder and send it to them
    that way.
    If they have MXF playback servers, that should work.
