Activity Forums Adobe Premiere Pro Exporting .MXF file to Quicktime Stretched
  • Exporting .MXF file to Quicktime Stretched
    Posted by Manny Rellesiva on August 28, 2008 at 8:31 am
    im using Premiere Pro CS3 ver3.2: project settings i selected was DVCPROHD 720p24p. Footages are captured from Panasonic AG-HVX200 P2HD. The clips were imported just fine in Premiere Pro, no problem. However, when i tried to export it as Quicktime, it exported as if it was stretched. How do I export it as the same resolution (size) as that of the original file without it being stretched? thanks in advance.
    manny
    Vince Becquiot replied 18 years ago 2 Members · 1 Reply
  • Vince Becquiot
    August 28, 2008 at 4:21 pm
    You are having issues because your pixel aspect ratio on the export is now 1.0 (instead of 1.33 for DVC Pro HD).
    What you need to do is change the horizontal resolution in your export from 960×720 to 1280×720.
    Vince
