Activity › Forums › Apple Final Cut Pro Legacy › exporting multiple sequences – best workflow
  • exporting multiple sequences – best workflow
    Posted by Jason Brown on July 14, 2009 at 3:35 pm
    Hey Guys,
    My workflow is using a QT ref as my source files in Episode Pro. I have multiple sequences, but I can’t seem to export several at one time to QT ref. I can use the Export Queue…but I can’t find the QT ref option in that output mode.
    Any ideas? Suggestions? Better workflows?
    -Jason
    Jason Brown replied 17 years, 2 months ago 2 Members · 2 Replies
  • Nicole Haddock
    July 14, 2009 at 3:50 pm
    When you drag your sequences into the Export Queue, highlight the batch or sequence, hit settings, and the popup window will give you a check box at the bottom to “make self contained” files. Uncheck that and you can make reference files.
  • Jason Brown
    July 14, 2009 at 5:10 pm
    I’m apparently blind…I completely missed that. Found it now! Thanks!
