Activity › Forums › Adobe Premiere Pro › Exporting multiple mono wav audio files to use with dts encoder
  • Exporting multiple mono wav audio files to use with dts encoder
    Posted by Fotis Dimitriou on November 26, 2010 at 2:39 pm
    Hello, I know PP has weak point in audio but anyway.
    I have a 5.1 sequence (6 audio files) and after setting the surround project to fit my needs I want to export them as multiple mono wav files to feed the dts encoder.
    Is there any way I can do it? Can PP export them and lebel each audio as let.wav, center.wav, etc..
    Also for stereo sequences, can I export the left and right channel eperatelly as mono wav?
    Thanks in advance
    Andrew Devis replied 15 years, 10 months ago 2 Members · 1 Reply
  • Andrew Devis
    November 28, 2010 at 2:38 pm
    Hi, yes you can I believe, you need to right click on the file in the project panel and you will find the audio options you need there to remap 5.1 and stereo to mono files – It’s called source channel mapping. These will then be added to your project panel and can be saved and used elsewhere.
    Sorry for few details I’m nowhere near my comp!
    Andrew
    … because it’s all about stories …
