Activity › Forums › Apple Final Cut Pro Legacy › exporting multiple green-screened clips in same seq.
  • exporting multiple green-screened clips in same seq.
    Posted by James Young on December 29, 2008 at 3:37 pm
    i have 35 or so clips in a sequence, all of which have been keyed and have had a background laid in behind them.
    my timeline looks something like this:
    https://img266.imageshack.us/img266/3266/timeline1si1.jpg
    now, my goal is to create individual .mov files out of each one of those clips, with all of the filter and green screen settings intact, as efficiently as possible.
    i tried using the nest command to create a new sequence out of each clip, and then batch-exported those sequences, and had some success, but the nesting was incredibly time consuming.
    is there any way to mass-nest into multiple sequences? or should i be going about this completely differently?
    as always, thanks so much in advance for your help.
    James Young replied 17 years, 9 months ago 6 Members · 10 Replies
  • 10 Replies
  • Rafael Amador
    December 29, 2008 at 4:21 pm
    Why don’t you just mark an IN and an OUT to each clip and export a Self-contained QT movie?
    rafael
    http://www.nagavideo.com
  • James Young
    December 29, 2008 at 4:36 pm
    i’m still quite the FCP newbie, so correct me if i’m wrong here, but wouldn’t setting an in and out for each clip require that i do 35 separate exports? or is there a way to do multiple in/out selections and then run one mass export?
  • James Disch
    December 29, 2008 at 6:50 pm
    I would break out your one sequence into 35 individual sequences. Then do a batch export from FCP. It will be a little time consuming to set up the sequences, but once you do it, and have the batch export going, you can walk away until all your files are done. It would be way better than having to wait for each file to export.
    James
    http://www.rapidlightproductions.com
  • James Young
    December 29, 2008 at 6:58 pm
    thanks for all of the help, guys.
    i was originally just option-c nesting each clip+background into a new sequence and batch exporting, and while the sequence setup time is a little annoying, i’d rather do that and then walk away for 30 minutes and do something else while it exports than mark, export, mark, export, etc. especially because its looking like i might have a few more of these to do, some upwards of 50 clips. blah.
    its a shame FCP can’t simultaneously nest multiple clips into multiple sequences, so i’d only have to execute the command once.
    good to confirm that i’m doing this as best as i can. helps with the monotony of the task a little.
    thanks so much again for taking some time to help, you guys are great.
  • Kevin Monahan
    December 29, 2008 at 7:04 pm
    I create a bin
    Drag all the clips I want to affect from the timeline into the bin and Select
    File > Batch Export
    Setup Batch Export Settings for Animation Codec with Millions of Colors +
    Click Export
    Walk Away
    Done
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • James Young
    December 29, 2008 at 8:27 pm
    kevin, that’s what i initially tried, but there didn’t seem to be a way to retain the background that i had placed behind my green-screen footage when dumping my clips into the new bin, and so that when i exported, all i got was the matte on a black background. if there’s a way to associate the clip with the background, let me know.
  • Rafael Amador
    December 30, 2008 at 1:28 am
    So making 35 duplicated sequences or 35 nests or 35 IN/OUT-Export.
    Rafael
  • Jeffrey Di lullo
    December 30, 2008 at 1:31 pm
    James,
    Based on looking at your sequence I’d suggest trying out FCPtoAE by Popcorn Island. https://www.popcornisland.com/downloads
    It is a FREE script for AE that allows you to import an XML of your sequence in FCP into a comp in AE. I have found that it work very well with sequences as simple as yours.
    Good luck,
    Jeffrey Di Lullo
    BBC&S Video Communicaitons
  • Alan Okey
    December 30, 2008 at 8:27 pm
    [Dave LaRonde] “An alternative: get Automatic Duck ($700), export your FCP timeline to After Effects”
    Or, as an alternative to Automatic Duck, try xm|Edit’s Traffic, a node-based editing tool for Final Cut Pro that is designed to simplify and automate complex workflows and repetitive tasks:
    https://www.xmedit.com/
    They have a demo movie depicting the exact scenario you describe:
    https://www.xmedit.com/case-studies/case-studies-visualfx.html
    Traffic is cheaper than Automatic Duck, and has a broader range of uses. Nothing against Automatic Duck (it’s a great app), but Traffic might be a better fit for your needs in this instance.
  • James Young
    December 31, 2008 at 4:25 am
    thanks for the software suggestions guys, and i really appreciate all of the advice.
    for now, the 35 nests/1 export seems to be fastest, but traffic looks like it would be a permanent solution to what is looking to become a permanent problem. thanks for the heads up.
    now, to convince my boss to drop the $300…
