Activity Forums Apple Final Cut Pro Legacy Exporting multiple frames as JPEG quickly from FCP
  • Exporting multiple frames as JPEG quickly from FCP
    Posted by Rory Hinds on March 5, 2006 at 10:42 am
    Hi there
    I have a video which I’ve captured using a Decklink HD and I need to grab multiply frames from the video as JPEG files.
    How can I do this quickly without having to do it one at a time.
    I remember there was a way you could do it with markers or something…. anyone know?
    Rory
    Rory Hinds
    http://www.whatismine.com
    Bob Auiler replied 20 years, 6 months ago 2 Members · 1 Reply
  • Bob Auiler
    March 6, 2006 at 12:20 am
    The quickest way I know of is to park your playhead on a shot, then do a match frame (f) then (shift-n),
    that will put a freeze frame in your Viewer. You can then drag that freeze from the viewer window to a bin
    and give it a name.
    After you have a bin full of stills, control click it and select batch export. An export queue window with
    all of your stills will open up, go to settings at the bottom of the export queue window
    and select Format> Still Image, then Options>JPEG. Click export and your on your way.
    Bob Auiler | bob.auiler@mvpcollaborative.com
