Activity Forums Adobe After Effects Exporting Multiple Ending PNGs on a sequence?
  • Exporting Multiple Ending PNGs on a sequence?
    Posted by Max Monty on October 5, 2018 at 6:43 pm
    I finished a video for a company that has 18 different community centers. The main video will remain the same, but the ending slide will change. All of the slides are PNG and will just be going over a white background. Is there a way to set a folder and do a batch export where every time a new export has finished it will move onto the next PNG ending?
    Thanks for any help!
    Max
    Max Monty replied 7 years, 10 months ago 2 Members · 2 Replies
  • Eric Santiago
    October 5, 2018 at 6:50 pm
    I can only think you would duplicate the sequence and change each with different endings.
    Then batch export to PNGs.
    Unless I’m missing something here?
  • Max Monty
    October 5, 2018 at 6:52 pm
    Yes that is the way I was originally going to do it. However, this is one video I have completed and when everything is done, there will be 18 different videos for 18 different communities. So all in all its about 324 videos. If I could figure out a way that After Effects could grab and replace every PNG automatically at the end, that would be amazing. Just seeing if this is possible.
